Fillet Welding: T-Joints with 10mm Plates
  • Thread starter Thread starter doan
    Plates Welding
This discussion focuses on the proper welding symbols for T-joints with 10mm thick plates in fillet welding. The consensus is that using an arrow to designate weld locations indicates a full-length weld at the specified legs. The "all around" symbol should be used when the intent is to weld around the entire joint. Clarification was sought regarding the applicability of the first case for joints with varying leg sizes, which remains unresolved.
  • Understanding of welding symbols and their meanings
  • Knowledge of fillet welding techniques
  • Familiarity with T-joint configurations
  • Basic principles of weld joint design
  • Research AWS A2.4 welding symbols for comprehensive understanding
  • Study fillet weld design considerations for T-joints
  • Learn about the implications of using the "all around" symbol in welding
  • Explore variations in weld joint configurations and their symbol representations
Welders, welding engineers, and students in welding technology seeking to enhance their understanding of welding symbols and T-joint fabrication techniques.
doan
Dear all,
I've one question about fillet weld.
Ex. i have T-joint with both plate are 10mm thickness. if i want weld around on leg of plate, so which symbol can i choose on both case below?
1. Both side of arrow is triangular and no around symbol.
2. only side of arrow is triangular and increase around symbol.
thanks so much!
Just use an arrow to designate weld locations. It will be interpretted as a full length weld at the designated legs on the arrow side of the joint. Use the all around symbol if that is the intent.
Thanks Chronos!
But around of legs having 2 small sides and 2 larger sides, can i use case 1 above for all?
Thanks
N-Doan
12K
  • · Replies 16 ·
  • · Replies 30 ·
