Final round: Integrating factors
ssb
Final round I promise!
Is there some sort of trick that can be applied to the following equation so that it is easier to process?
\frac{dy}{dt}=\frac{1}{t+y},\:y(-1)=0
Somebody told me that the equation can be made easier by reinterpreting it with y as the independent variable and t as the dependent variable. I still have a vacant look about my face now as I did back then.
I know that \frac{dy}{dt}=\frac{1}{\frac{dt}{dy}} but when I try to apply it to my initial equation, I get the same thing I started with.
'Somebody' is right. It turns the equation into 1/t'=1/(t+y). Or t'=t+y. That does look a bit simpler, right?
Then you just solve it the normal way as if t' were y'? I don't mean rename everything but just work the problem through solving for f(y) instead of y(t)?
Just fyi I love you.
Exactly...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
