Final temperature for two blocks of iron placed in contact
Two blocks of iron at different temperatures are placed in contact, and the final temperature is determined to be 20°C. The initial attempt to solve the problem incorrectly used the equation m(x-10) = 2m(x-25), leading to an incorrect result. The correct approach involves using the principle of conservation of energy, where heat gained equals heat lost, resulting in the equation Q = mc(Tf - Ti). Simplifying this equation correctly yields the final temperature of 20°C without needing to guess which block gains or loses heat. The discussion emphasizes the importance of maintaining consistent signs in heat transfer calculations.
dwight_v
Member advised to use informative thread titles for Homework Help requests.
Two blocks of iron, one of mass m at 10.0C and the other of mass 2m at 25.0c, are placed in contact with each other. If no heat is exchanged with the surroundings, which of the following is the final temperature of the two blocks?
A)10
B)15 .
D) 20C ( this is the answer)
I tried to solve doing m(x-10) = 2m(x-25) but then I get x = 40. The answer is 20, but I don't see why you would divide x by 2. [/B]
What do you think should happen, can you give a range between where you think the final temperature should lie? Should any of the iron blocks lose heat or gain heat?
Use this to think about the signs.
Likes Delta2
ya i think i got it ==> m(x-10) = 2m(25-x) because heat gained = heat lost
Likes Delta2
Moderator's note: Thread title changed to make it more descriptive of the question being asked.
I know you figure it out, but I'm going to caution you here because you're making some ad hoc decisions to fit the answer, especially when you reverse the sequence of (25 - x) in your second term.
Follow this rule: ΔT always means Tf - Ti. All you need to do is to write the specific heat equation in just one way:
Q = mc ΔT
In this case, Q = mc(Tf - 10C) + 2mc(Tf - 25C). --- (1)
Now, the simplification here is that (i) Q = 0, since there is no heat loss anywhere, and (ii) c is the same for both. So that equation simplifies to
Tf - 10C + 2Tf - 50C = 0
This gives
3 Tf = 60 C
Thus,
Tf = 20 C.
I did not have to "think" which one loses or gains heat. All I did was set up equation (1), and then I follow the mathematical rule. If I want to know which one gained or lose energy, all I have to do is use the value of Tf that I got, and then look at which of the term in Eq. 1 is positive (heat gained) and which one is negative (heat loss).
The key thing here is that question like this is a TRAP in terms of jumbling up the SIGNS. If you keep the whole equation only to one side of the equation, keeping only "Q" on the other side, you'll never go wrong and you'll never have to insert the sign by hand.
Zz.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
