Final temperature of diamond using Cv
8 replies · 2K views · last reply
Ryomega
At low temperatures, Cv of solids is given by:
Cv = D([itex]\frac{T}{\Theta}[/itex])3
where:
D = 1.94*10^3
[itex]\Theta[/itex] = Debye Temperature, for diamond 1860K
If 100J of heat is transferred to 1mole of diamond, initially at 10K. Calculate the final temperature.
Q = mCv(Tf-Ti)
This is a straight forward question as the equation becomes:
Q = mCv(Tf-Ti)
Tf = [itex]\frac{Q}{mC}[/itex]+Ti
So the real problem I'm having is the fact that Cv is a function of T and T is changing as heat is being put in.
So how do I go about this question?
Thanks in advance
Oh and I'm guessing mass is just 1 molar mass of carbon
dQ = CvdT
Plug in your expression for Cv and integrate from 10 to T:
Q = 1000J = ∫CvdT' from [10, T]
then solve for T.
Oh... that would do it... *Face Palm*
Can't BELIEVE I didn't see that.:rolleyes:
Thanks!
Actually how do you propose to do that?
Cv is the only variable changing with Temperature so:
Cv = D[itex]\int[/itex][itex]\frac{T^3}{θ^3}[/itex]
Cv = [itex]\frac{D}{θ^3}[/itex][itex]\int[/itex]T3 (from 10 to Tf)
Cv = [itex]\frac{D}{4θ^3}[/itex] (T4f-104)
Q =mCv (Tf-10)
Q =[itex]\frac{mD}{4θ^3}[/itex] (T4f-104)
Let A = [itex]\frac{mD}{4θ^3}[/itex]
Q =A (Tf-10) (T4f-104)
At this point it becomes pretty much impractical to solve. Am I doing something wrong?
Q is the heat you added to the system, 1000J. It's just simple algebra from there.
If we expand it (Q = 100J btw)
[itex]\frac{T^5}{10}[/itex] -T4-103T-104=[itex]\frac{10}{A}[/itex]
I suppose you're going to tell me I have to do long division? No easier way?
Q =mCv (Tf-10)
No, your integration is wrong here.
Q = ∫CvdT = A(T4 -104)
Q/A + 104 = T4
T = (Q/A + 104)1/4
Wow... I should go back to school. Thanks a lot.
