Find Currents & Vab with Reversed Polarity Battery in Circuit
The discussion focuses on solving a circuit problem involving a 10.00V battery that has been reversed in polarity. Participants discuss methods to find the current in each branch and the potential difference Vab between points a and b. They suggest using mesh analysis or Kirchhoff's voltage law to create equations for the unknown currents, emphasizing that the equivalent resistance (Req) is not necessary for solving the problem. Confusion arises regarding the treatment of multiple resistors and branch currents, with advice given to focus on the loop analysis instead. The conversation highlights the importance of applying circuit laws correctly to simplify the problem-solving process.
jelsliger7
The 10.00V battery in the figure is removed from the circuit and reinserted with the opposite polarity, so that its positive terminal is now next to point a. The rest of the circuit is shown in the figure. Find a, the current in each branch and b, the potential difference Vab of point a relative to point b
V = IR
1/Req=1/R1+1/R2+...+1/Rn
Req = R1 + R2 + R3
the sum of the current at each junction =0
the sum of the potential = 0 (loop rule)
R in series
R' = 2+3 = 5
R''= 1+4 = 5
Now in series
1/Req = 1/R' +1/R'' +1/10
=1/5 + 1/5 + 1/10 = 5/10
thus Req = 2.0ohms
I=V/R
I=15/2 = 7.5A
i think i am just confused as to what to do if there are two different voltage supplies, how do i find Req?
Please help thanks:)
The fact that they want you to find two branch currents calls for a much easier method. Just use mesh (or loop) analysis. You will get two equations and two unknowns (the branch currents).
To find Vab, just apply KVL around the loop containing points a and b. Better yet, you don't have to go around the entire circuit. Just start at point a, go to straight to b and work your way clockwise back to point a.
Given the topology of the circuit, I'm afraid that there isn't any easy method of finding Req wrt t0 points ab. Besides, you don't need req to solve this problem. Thinking about it only confuses you.
hey i am still confused, how can i only have 2 unknowns when i have multiple resistors won't they all have different currents flowing through them? and then what exactly is the branch current?
thanks for your help!
sorry i didn't reply earlier i just had my reading week and i was out of town
well if you do not know mesh currents, then use Kirchoff voltage law to make 3 equation with 3 unknowns
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
