Find Electric Flux through cube's side, point charge on corner
To find the electric flux through the top side of a cube with a point charge at the origin, one approach is to use Gauss's law and symmetry. The cube's corner is at the origin, which complicates the assumption that the flux through one side is 1/6th of the total flux. Instead, it is determined that eight cubes are needed to completely surround the charge, leading to each cube subtending 1/8th of the sphere's total flux. The discussion also highlights the challenge of setting up the double integral for calculating the flux directly. Ultimately, participants express satisfaction with the symmetry approach and the integral solution despite initial confusion.
DieCommie
My problem is this,
Find the electrix flux through the top side of a cube. The cube's corner is on the origin, and is 'a' units on length. The charge 'q' is located at the origin, with the corner of the cube.
I am thinking I need a double integral. One to swipe the box in the y direction (theta), and one to swipe in the x direction (phi).
So, I know the component of the electric field perpendicular to the surface is (k*q*cos(theta))/(a*cos*theta)^2 . So I think I need to integrate this from 0 to (pi/4), then integrate again.
But how to set up the second integral is where I am confused...
Or maybe I am off track all together! Thx for any help
DieCommie said:
My problem is this,
Find the electrix flux through the top side of a cube. The cube is centerd on the origin, and is 'a' units on length. The charge 'q' is located at the origin.
Use Gauss' law and symmetry to show that the flux through one side of the cube is 1/6th of the total flux through a gaussian sphere centred on the origin.
AM
Thx for the reply.
Im sorry, I mis stated my problem I will edit it.
The cube is not centered on the origin, its corner is at the origin with the charge.
So the flux through one side will not necessarly be 1/6th of the flux.
DieCommie said:
Thx for the reply.
It's not 1/6 but you still can do it by symmetry. Hint: if you would surround the charge entirely by cubes, how many would you have to put there (so that the charge is completely surrounded)? By symmetry, the flux in each of those cubes will be the same and equal to the total flux over the number of cubes.
It would be quite a pain to do with an integral
Likes davidbenari
DieCommie said:
Thx for the reply.
You have to find the solid angle subtended by the cube face. Use Nrged's suggestion. The three faces that intersect the charge have no flux since their areas are perpendicular to the field. (E\cdot dA = 0). It takes 8 cubes to cover a complete sphere centred at the origin of radius a, so each cube subtends 1/8th of the sphere. So each surface has 1/24th of the total flux through a gaussian sphere centred on the origin.
AM
I see the solution perfectaly now. Thank you all, you answered my question well.
I did infact get the double integral too, wow what a mess. But getting the double integral was satisfying. :biggrin:
can u please explain it a bit. I can't understand this thing. How would it take 8 cubes to cover a complete sphere?
Note that the cubes are arranged so that their corners are at the origin.
I can do this using the gauss's law and the symmetry. Can you explain how did you do this using the integrals. I can't seems to get the correct answer when I'm using the integrals.
Realize you are replying to a post made over 5 years ago.
Yes I know. I was curious, and can't figure out what I'm doing wrong.I couldn't find any online resource that explains this problem using integrals. so it was worth a try.
