Find Energy Stored in Two Parallel Springs
The discussion focuses on calculating the initial velocity of a block compressing two parallel springs, one with spring constant k1 and another with k2. The solution involves applying Hooke's Law and energy conservation principles, leading to the equation (1/2)M v^2 = 1/2 k1 d2^2 + 1/2 k2 (d2-d1)^2. The user successfully derived the energy stored in the springs by integrating the force over distance, confirming the results through separate calculations for each spring's energy storage.
  • Understanding of Hooke's Law and spring constants (k1, k2)
  • Familiarity with energy conservation principles in mechanics
  • Ability to perform integration for calculating areas under curves
  • Knowledge of basic kinematics and dynamics
  • Study the application of Hooke's Law in complex spring systems
  • Learn about energy conservation in mechanical systems
  • Explore integration techniques for calculating work done by variable forces
  • Investigate the dynamics of multiple spring systems in physics
Students studying physics, particularly those focusing on mechanics and spring dynamics, as well as educators looking for practical examples of energy conservation and integration in real-world applications.
c7ng23
There are two springs, one long spring of constant k1 and it is inside a smaller spring of constant k2. Both springs follow Hooke's Law. A box of mass M moves without friction and compresses spring 1 a distance d1 where it hits spring 2. Spring 1 and 2 then compress further distance d2. Solve for the initial velocity of the block.
F = -kx
U = 1/2 mv^2 = 1/2 kx^2
I was able to get the solution from the following: (1/2)M v^2 = 1/2 k1 d2^2 + 1/2 k2 (d2-d1)^2 and solving for v. I also thought I could get the solution from finding the area under a force vs distance curve but I was unsuccessful. In this attempt I found the area under the small triangle formed by k1 slope, the area of the larger triangle formed by k1+k2 and the little rectangle beneath.
The equation was: 1/2 k1 d1^2 + 1/2 [(k1+k2)d2 - k1d1]*(d2-d1) + k1d1d2
I attached a picture of the initial scenario and graph. Any help is greatly appreciated, thanks!
It says a further distance d2 which you have interpreted as d2-d1.
This may be the problem. Try taking it d1+d2 on graph instead of d2 and check for the answer.
I wanted to update- I found the area under the curve by integrating and it matched the answer as if we considered the energy stored in the compression of the springs separately:
[tex]\int ^{d1}_{0}k_{1}x +\int ^{d2}_{d1} (k_{1}+k_{2})x +k_{1}d_1[/tex]
[tex]\ \frac{1}{2} k_{1}d_{1}^2 + \frac{1}{2}(k_1+k_2)(d_2-d_1)^2 +k_1d_1(d_2-d_1)[/tex]
[tex]\ \frac{1}{2}k_1d_1^2 + \frac{1}{2}(k_1d_2^2 +k_1d_1^2-2k_1d_1d_2 +k_2d_2^2+k_2d_1^2 - 2k_2d_1d_2) +k_1d_1d_2 - k_1d_1^2[/tex]
[tex]\ \frac{1}{2}k_1d_2^2 + \frac{1}{2}k_2d_2^2 + \frac{1}{2}k_2d_1^2 - k_2d_1d_2[/tex]
And this is the same as the two springs separately:
[tex]\ \frac{1}{2}k_1d_2^2 + \frac{1}{2}k_2(d_2-d_1)^2[/tex]
  • · Replies 19 ·
  • · Replies 17 ·
