Find Initial Speed of Porsche Using Inelastic Collision
To find the initial speed of a Porsche using inelastic collision principles, it's essential to apply the momentum conservation equation, which states that the total momentum before the collision equals the total momentum after. The problem is framed as a 2D scenario, requiring separate momentum calculations for both North/South and East/West directions. The discussion emphasizes the importance of using the correct equations and values, noting that the initial setup may seem confusing due to the lack of time information. Additionally, the final speed of the combined vehicles post-collision can be determined using accelerated motion formulas, focusing on distance and acceleration without time. This approach will clarify the solution process for the problem at hand.
7skk
blah blah blah
momentum = momentum'
mv + mv = (m1+m2)v
(Uk)N = friction force
It's hard to find how to start with randomly given values.
Thank you so much for your help! :D
It is a 2D problem so you must write two headings for North/South and East/West. Then write that "momentum before = momentum after". Follow that up with an "mv" for each moving object in each part. Then put in your numbers. If you are still having trouble, show us your work and someone will be pleased to pitch in and help!
No, I don't think any of it makes sense. Even the
1380kg v + 2304kg v = 3684kg v
can't be right because before the collision you don't have two vehicles moving in either the north/south or east/west direction. Got to write the two headings and two separate equations!
You do have to find the speed of the pair of them after the collision from the friction and distance information given. That is an ordinary 1D accelerated motion problem, a little complicated because there is no time info. Do you have the accelerated motion formula with v's, d and a but no t? That is perfect for the job. If you don't have it you could derive it by solving Vf = Vi + at for t and subbing into
d = Vi*t+.5*a*t^2. Or you could sketch the v vs t graph and use the fact that the area under the graph is the distance.
