Find Net Force Neutral Point b/w Q1 & Q2 Charges
To find the net force neutral point between two charges, Q1 and Q2, the equation Fe=kq1q2/r^2 was applied. The calculations resulted in a quadratic equation yielding roots of approximately 0.998459 m and -0.0384593 m. When considering the placement of a third charge (Q3), the order of charges affects the solution, leading to two negative roots when Q1 is placed before Q2. The relevant solution for Q3's position, considering the requirement for a positive distance if it is to the right of Q1, is approximately 0.998459 m. The individual expresses uncertainty about the correctness of their solution but believes it aligns with the problem's requirements.
Sean1218
A charge, Q2 = -7.00x10^-6 C, is 8.00 cm to the right of charge Q1 = 6.00x10^-6 C. Where can a third charge be placed, along the line connecting Q1 and Q2, such that it experiences no net force? Give distances relative to Q1 and use a plus sign if the third charge is to the right of Q1
Fe=kq1q2/r^2
I did q1/x^2 = q2/(x+0.08)^2 and solved for x. I got a quadratic which gave me roots 0.998459 and -0.0384593. This is assuming that the order is Q3 then Q1 then Q2.
If I do it with the order as Q1 - Q2 - Q3, then I get two negative roots (the more negative one still matches up with 0.998459 if I take into account the 0.08 between Q1 and Q2).
So, would my answer be -0.998459 m because Q3 is to the left of Q1 and the question said to make it positive is Q3 is to the right? I have one try left to get this right, but I'm not confident this is correct.
Looks right to me.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
