Find resistance, inductance, and the time constant for an RL circuit.
The discussion revolves around an RL circuit connected to a 5.0V battery, where participants are tasked with determining the resistance (R), inductance (L), and time constant (τ) using provided current and time data. The problem involves analyzing the relationship between current and time in the context of RL circuit behavior.
  • Participants explore the use of the provided formula for current to derive resistance and time constant. Some question how to effectively utilize the data points to find τ or L, while others suggest evaluating the current at specific time intervals.
Some participants have provided calculations based on the relationship between current and time constant, with one suggesting a value for τ and subsequently calculating L. There appears to be a sense of validation among participants regarding the derived values, though explicit consensus is not stated.
Participants are working with a specific data table and are attempting to derive values based on the relationships defined in the problem statement. There is mention of potential confusion regarding the algebraic manipulation of the equations involved.
rail2k
A 5.0V battery is attached to an RL circuit. The current is given by the formula: I = V0/R(1-e-t/τ), where I0 is the steady-state current, and τ is the time constant for the circuit.
Using the data table provided, determine τ, R, and L for this circuit.
Code:
 I(mA) | t(μs)
   0   |   0
 3.94  |   1
 6.32  |   2
 7.77  |   3
 8.65  |   4
 9.18  |   5
 9.50  |   6
 10.0  |   ∞
I = V/R
τ = L/R
εL = -ε0e-Rt/L
I = ε0/R(1-e-Rt/L)
So I started by concluding that ε0 = V0 = 5 V and I0 = 10 mA.
Using that I determined that R = V0/I0 = 5/0.01 = 500 Ω which gives me resistance.
I know that once I find τ or L I can easily find the other one, but I can't figure out how to find either of them. At first I thought I could simply work I = V0/R(1-e-t/τ) algebraically to give me τ, but I end up getting undefined from using the natural log with a negative number.
I feel like I have to use the data to find one of them (probably τ?) by using the relationship between two of the data points but I'm sort of stuck at this point.
When t = 1 time constant, what is the current?
Then, what is the time constant?
Then, expess the time constant in terms of L and R.
Ah, so when t = τ, I = 5/500(1-e-1) ≈ 6.32 mA.
So τ = 2 μs from the data and therefore L = 500*0.000002 = 1 mH.
That seems correct, right?
It does to me! :smile:
Good going.
Thanks a lot! Can't believe the answer was so close, lol.
  • · Replies 18 ·
