Find speed with friction force and no mass?
The problem involves a ski sliding down a 22-degree incline with a specified coefficient of friction. The original poster seeks to determine the ski's speed at the base of the incline and how far it travels along a level surface, using energy methods despite lacking mass information.
  • Participants discuss the relationship between mass, friction, and acceleration, questioning how to calculate the force of friction without knowing the mass. There are attempts to manipulate energy equations and force diagrams to derive relationships between the forces acting on the ski.
Some participants have offered insights into the relationships between gravitational forces, normal forces, and friction. There is recognition that mass can be canceled out in certain equations, leading to a clearer understanding of the acceleration. However, the original poster expresses difficulty in connecting these concepts to find the final velocity.
The discussion highlights the challenge of solving the problem without explicit mass values and the implications of using energy methods in this context. Participants are exploring various interpretations of the forces involved and their effects on the ski's motion.
NewDaddyJones
Find speed with friction force and no mass??
A ski starts from rest and slides down a 22 degree incline 75m long. If the coefficient of friction is 0.090, what is the ski's speed at the base of the incline? If the snow is level at the foot of the incline and has the same coefficient of friction, how far will the ski travel along the level? Use energy methods.
Delta U = Delta K
mgh = (1/2)mv2
Wext = Delta K + FK * d * sin(theta)
Delta K = FK * d * sin (theta)
I am stuck, I've tried so many manipulations of formulas that just wouldn't work because I was not provided with a mass. I tried determining what the mass was but I simply couldn't. I tried finding mass from mgh=(1/2)mv2 but that doesn't work out, and v does not simply = sqrt.(2gh) because of the friction.
How can I figure out the force of friction without mass, if it's possible? Or should I be asking how do I figure out the mass?
How do you calculate the force of friction?
ehild
FK = MuK * FN
FK = MuK * mass * acceleration
I know you could cancel the masses out and find the acceleration, etc. but that doesn't help me out here, I've tried it about 2-3 times.
Okay not sure if noticed this but if you draw out a force diagram of your system you should find that the normal force is equal to a trigonometric component of the weight. Therefore, you can calculate the force from the weight and the angle and watch the masses cancel. Once that's done you can work out the energy the ski loses to friction (i.e. the work done by friction) as you know how long your slope is.
Hope that helps.
NewDaddyJones said:
FK = MuK * FN
FN is the normal force. Does the skier move normal to the slope? So what is the acceleration in your formula FK = MuK * mass * acceleration ?
ehild
The skier does not move normal to the slope.
The force pulling the skier down the slope is gravity. If you split the gravitational force into two components you should find these components equal to the friction and the normal force (because of Newton's 3rd Law). Therefore the acceleration of the normal force is equal to one component of the gravitational acceleration g.
Does that make sense?
Okay, I understand your concept, however I don't understand how that can eventually give me the final velocity or friction force for that matter.
I applied that concept:
FN = mg * cos(theta)
mg * cos(theta) = ma ... masses cancel out
g * cos (theta) = a
But dealing with coefficient of friction, so:
g (sin (theta) - MuK * cos (theta) = a
^Using that formula, my a = 2.85 m/s2, however, I can't figure out my velocity from here.
okk well now that you have your acceleration just solve for velocity using the simple kinematics equations using what you know
Wow, yes - I can't believe I overlooked that, I had the acceleration the whole time, however I was looking at all the equations involving time, overlooking the formula: V2 = Vo2 + 2a (X-Xo)
Thank you, answer is Vf = 21 m/s
  • · Replies 20 ·
  • · Replies 16 ·
