Find the derivative of the question
  • Thread starter Thread starter ASidd
    Derivative
ASidd
(9x-8)/ 2(sqrt(3x-4))
Vu'-Uv'/v^2
i.e. quotient rule
I get
V=2(sqrt(3x-4) u=9x-8
V'=3((3x-4)^-1.5) u'=9
When I put this into the equation and solve I get
9x-8(sqrt(3x-4))/6x-8
But the answer is 3(9x-16)/4((3x-4)^1.5)
Help Please?
Vu'-Uv'/v^2
i.e. quotient rule
I get
With v= 2sqrt(3x- 4)= 2(3x- 4)^1/2, v'= 3(3x- 4)^-(1/2)= 3(3x- 4)^(.5-1)= 3(3x- 4)^-.5, not "-1.5". That's your basic error.
So u'v- uv'= 9(2(3x-4)^1/2)- (9x- 8)(3(3x-4)^-1/2
To combine those two square roots, use the fact that (3x-4)^1/2= (3x- 4)(3x-4)^-1/2 so we can factor (3x- 4)^-1/2 out: (3x-4)^-1/2(18(3x- 4)- 3(9x- 8))= (3x-4)^-1/2(54x- 72- 27x+ 24)= (3x- 4)^-1/2(27x- 48)= (3x- 4)^-1/2(3)(9x- 16).
Can you finish?
Help Please?
By the way, with that power in the denominator, so you will need to use the chain rule, anyway, it might be simpler to write the function as (1/2)(9x- 8)(3x-4)^-1/2 and use the product rule rather than the quotient rule.
Writing fractions without LaTex should be punishable by death
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
