Find the force-couple system check my answer please
  • Thread starter Thread starter doubled
    System
The discussion revolves around calculating the equivalent force-couple system for a car problem involving forces at point A. An upward force of 7000N and a horizontal leftward force are analyzed, with the resultant force making a 15-degree angle with the vertical. The participant calculated the leftward force as -1875.6N and determined the moment using the cross product, yielding a moment of -7938 N. There is confusion regarding the sign of the moment, as the book states the answer is positive, while the participant believes it should be negative due to the clockwise direction of the moment. Clarifications indicate that the moment's direction can be interpreted differently depending on the reference frame.
doubled
The problem is actually for a car but I'm going to simplify it so it''s easier to type on here. Basically there's a point (let's call it point A) located at (-1,-.5)m. An upward force A acts at point A with 7000N and a horizon force F acts on point A but points left so it's negative. The resultant force due to A&F makes an angle 15 deg w/ respect to the vertical. Determine the equivalent force couple system at the origin. Basically I find the moment.
i choose to do the cross product M=rxR, where R=resultant force
1. I found force F by doing tan(15)=F/7000 which gave me F=1875.6N <<<magnitude or -1875.6N
2. so R=7000i-1875.6j N
3. Then I found r by doing point A-origin which would be <-.5,-1>-<0,0> which got me -1i-.5j m
Then I took the cross product rxR and got -7938 N.
The answer in the book was 7938 N. I don't understand why they had a positive answer, it's obvious that the answer should be negative because the moment is acting in a clockwise direction.
welcome to pf!
hi doubled! welcome to pf! :wink:
doubled said:
… there's a point (let's call it point A) located at (-1,-.5)m. An upward force A acts at point A with 7000N and a horizon force F acts on point A but points left so it's negative.
… it's obvious that the answer should be negative because the moment is acting in a clockwise direction.
yes, you're right :smile:
(but it should be Nm, not N, of course)
A is left and down from the origin, the force is left and up, it clearly goes to the left of the origin, so the moment is clockwise, which is negative
The problem is actually for a car …
you haven't over-simplified this, have you? clockwise from one side of the car is anti-clockwise from the other :wink:
Umm i don't think so, but thanks. The way they drew the forces was in a xy plot which the 7000N going up and F going left at the same point
