Find the Potential as a function of position
To find the electric potential as a function of position along the x-axis due to a uniformly charged rod along the y-axis, one must integrate the potential contributions from each infinitesimal charge element. The potential is expressed as V(x) = ∫(0 to L) (k/r) dq, where r is the distance from the charge element to the point on the x-axis. The charge element dq can be expressed in terms of dy, and r can be determined using the Pythagorean theorem. Proper integration will yield the desired potential function. Understanding these relationships is crucial for solving the problem effectively.
prace
A rod of length L carries a charge Q uniformly distributed along its length. The rod lies along the y-axis with one end at the origin. Find the potential as a function of position along the x-axis
dV=\vec{E}\cdotp d\vec{l}
V=\frac{kq}{r}
I think I am to use the first equation posted, but I am not sure how to relate it to the x-axis, if the rod lies along the y-axis. Also, what is the displacement here? I am assuming it is just dy?
V=\frac{kq}{r}
You have to integrate along the rod from y = 0 to +L.
V(x) = \int_{0}^{L} \frac{k}{r}dq
Work out the expression for dq in terms of dy. Work out the expression for r in terms of x and y (think: Pythagoras).
AM
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
