Find the Slope of the Secant Line PQ for x-values .5 to 1.001
To find the slope of the secant line PQ for the curve y=46x²+5, the correct points for Q were calculated using various x-values, yielding coordinates such as (.5, 16.5) and (.9, 42.26). The slope formula, which is the change in y over the change in x, was incorrectly applied using the point (1, 13) instead of the correct point (1, 51). Most of the calculated slopes were accurate, but the first slope of 690 was identified as a significant error, likely due to a misunderstanding of the formula. The discussion emphasized the importance of using the correct coordinates and the proper slope calculation method. Clarification on the secant line concept and the correct application of the slope formula was provided.
Destrio
The point P(1,51) lies on the curve y=46 x2+5.
(a) If Q is the point (x,46 x2+5), use your calculator to find the slope of the secant line PQ (correct to six decimal places) for the following values of x.
.5, .9, .99, .999, 1.5, 1.1, 1.01, 1.001
I plugged all of the values of x into point Q, getting values of
(.5, 16.5)
(.9, 42.26)
(.99, 50.0846)
(.999, 50.908046)
(1.5, 108.5)
(1.1, 60.66)
(1.01, 51.9246)
(1.001, 51.092046)
I then did (13- y)/(1-x) for each of the points getting:
690
87.5
91.54
91.959
115
96.6
92.46
92.046
Somewhere I have gone wrong
Any help would be much appreciated
Thanks
Sorry, but what is the secant line?
Okay, I agree with your points. It may be worth looking at them in a different order:
.9, .99, .999, 1.001, 1.01, 1.1, 1.5 But that really doesn't matter in this problem.
Now, I'm wondering - for the slope of the secant line, you would probably be using the slope formula which is change in y over change in x. My question is, where on Earth did you get the point (1,13) to plug into that formula?? Did you get the (13-y)/(1-x) from another example? If so, in that example, (1,13) was a point specific to that particular example.
edit: You listed the point on the curve that eventually you're going to be wondering what the slope of the tangent is at that point. That point is (1,51), not (1,13)
edit edit: as I ran through your numbers, most actually appeared to be correct for the slope. Check those again.
I also looked at your problem another way - rather than actually plugging a y value into the slope equation, I plugged in "46x^2 + 5" for the y value (and left x as x) and simplified first. Just coincidentally, it simplified a lot, making the problem easier to calculate slopes.
Actually, only the first couple answers have mistakes; one might be a typo. The first slope you have: 690, is off by a factor of 10.
The "secant" is a line that crosses the curve in two differnt places. If a secant crosses the line in (.5, 16.5) and (.9, 42.26) then its slope is (42.26- 16.5)/(.9- .4) = 51.52. HOW exactly did you get 690?
And, by the way, you say you are using (13- y)/(1- x), but told us that P was the point (1, 51), not (1, 13)!
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
