Find the volume of the region bounded by the planes (Multiple Integration).
s3a
Find the volume of the region bounded by the planes 7x + 6y + 8z = 9, y = x, x = 0, z = 0.
Multiple integration.
My attempt at a solution is attached. To test, I computed the answer with Wolfram Alpha which yielded an incorrect answer of 243/5488.
Any help in solving this problem would be greatly appreciated!
Thanks in advance!
You have decided to integrate with respect to z, then y, then x so look at the projection down to the plane z= 0. When z= 0 the plane 7x+ 6y+ 8z= 9 becomes the line 7x+ 6y= 9 which intersects the x-axis at (9/7, 0) and the y-axis at (0, 3/2).
So x will range from 0 to 9/7 and, for each x, y will range from 0 to (9- 7x)/6. In your attachment, you have the equation y= (9- 7x)/6 but, for some reason, you show the upper limit of the "dy" integral as just x rather than (9- 7x)/6.
My latest triple integral (in the image I just attached) is wrong. Did I misinterpret what you said?
I re-attempted the problem based on some new stuff I've learned but I still get a wrong answer. (I attached my latest work.) Could you please tell me what's wrong in the setup?
I've been reading how to do this, you want to take a double integral of your plane as follows:
$$ \int_0^{\frac{9}{7}} \int_0^{\frac{9-7x}{6}} \frac{9-7x-6y}{8} dy dx $$
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
