Find the wavelengths Kα, Kβ , Lα and Lβ from elemental Cu
The discussion focuses on calculating the wavelengths of Kα, Kβ, Lα, and Lβ x-rays emitted from copper using the Rydberg formula with a mass correction. The user attempted to calculate the wavelength for Lβ but received incorrect feedback from WebAssign. Key questions raised include the choice of quantum numbers and the atomic number (Z) used in the calculations, with Z set at 29 for copper. There is confusion regarding the application of the formula, particularly the selection of n values for the transitions. The thread emphasizes the importance of correctly applying the Rydberg formula and ensuring accurate inputs for the calculations.
AlphaLibrae
Problem: "What are the wavelengths of the characteristic Kα, Kβ , Lα and Lβ x-rays emitted from copper? Remember to use a Rydberg constant with the reduced mass correction made for elemental copper."
Givens:
Energy levels given:
Kα (2,1)
Kβ (3, 1)
Lα (3, 2)
Lβ (4, 2)​
Prompt and energy levels here: https://imgur.com/ygtSCWx
No relevant equations were provided for this assignment. The prompt hinted to use the Rydberg formula, but since I took into account the mass correction for elemental copper was made. I used the following equation:
1/λ=RZ^2((1/n^2)−(1/n^2))
[/B]
For LB (2,1), here is how I calculated the wavelength.
1/λ=RZ^2((1/n^2)−(1/n^2)) = (1.09737*10^7) * ((1/2^2) - (1/4^2))
λ = 0.14 nm
However, WebAssign has marked this wrong. Any suggestions?
Why did you use 2 and 4 for the n values? What value did you use for Z?
Sorry, meant to say Lβ (4, 2) .For Z, I used 29.
How did you get such wildly different numbers for the 4 lines (including one negative)?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
