Find Thrust on Cube Half-Filled w/ Water & Oil
  • Thread starter Thread starter Maybe_Memorie
    Pressure Thrust
The discussion focuses on calculating the thrust on a vertical face of a cube-shaped tank that is half-filled with water and oil, with the tank tilted at 45 degrees. Participants clarify that the oil, with a relative density of 1.2, is indeed heavier than water, which affects pressure calculations. The pressure at the center of gravity must consider both fluids separately, and the correct approach involves integrating the pressure contributions from each fluid layer. The initial calculations presented were incorrect, leading to confusion about the thrust value. Ultimately, understanding the pressure dynamics and applying Pascal's law is crucial for accurate results.
Maybe_Memorie
A closed tank in the shape of a cube of side root 2 is half full with water and half with oil of relative density 1.2. The tank is placed on a horizontal table and is then tilted about one edge until the faces about this edge are inclined at 45 degrees to the horizontal. See diagram.
If the oil and the water are not mixed, find the thrust on one of the vertical faces, the side facing you in the diagram.
Pressure, P = h rho g
Thrust = PA
The water is on the top half because the oil is heavier. The pressure at the top half due to the water is {tex}hrhog{tex}, where h is the depth of the centre of gravity. Using Pythagoras, the height of the heighest point above the half way line is 1. CoG is 1/3 from base along median, so depth of CoG is 2/3.
P = 2/3(1000)g = 2000g/3 Pa.
For oil, Pressure = 1/3(1200)g = 400g Pa.
Total pressure = 3200g/3 Pa. Area of one face = 2.
Thrust = 2133.3333g N. The correct answer is 2066g N.
Where am I going wrong?
1 - Oil is heavier than water? Hmm... You should reconsider this.
2 - If you don't tilt the tank, how will you calculate the pressure at the bottom? Is this pressure due to either water or oil? Or you must consider both? From this, how will you change your calculation of the pressure at the bottom half of the tilted tank?
3 - How did you get the formula F=PA=H\rho gA where H is the depth of the center of mass? If it's wrong, nothing to say. If it's right, you must derive it. You should calculate the element force dF on an area of dA, which consists of points from height h to height h+dh, and then sum up (or compute an integral). This is usually considered the more appropriate way.
1. The oil in this scenario is heavier than water. Water has a relative density of 1, the oil has a relative density of 1.2, so the oil is heavier.
2. I don't know, that's the problem. You have to consider both, I'm assuming.
3. The formula is in my textbook.
1 - Okay, you're right. I got the right answer with oil's density is 1200.
2 - It's heavier when there are 2 things weighing down on you than when there is 1 thing, right?
Consider one half at a time, don't mix them.
_ For the top half: You have P and A of the top half, then you can calculate the force on the top half.
_ For the bottom half: You must add the pressure due to the water. Remember Pascal's law? The pressure of the water should be transmitted into the oil.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
