Find unknown current in circuit, voltage division law
The forum discussion focuses on calculating the unknown current (IL) in a circuit using the voltage division law and Kirchhoff's rules. The user initially struggles with the absence of a potential difference but eventually derives that V = 1.2V for the circuit node. By applying Ohm's law (V = IR), the final calculation yields IL = 1.6 x 10-4 A. The discussion emphasizes the importance of correctly applying circuit analysis techniques, including Kirchhoff's Current Law (KCL) and voltage division.
  • Understanding of voltage division law
  • Familiarity with Kirchhoff's Current Law (KCL)
  • Basic knowledge of Ohm's Law (V = IR)
  • Ability to simplify circuits using equivalent resistance
  • Study advanced applications of Kirchhoff's laws in complex circuits
  • Learn about Thevenin's and Norton's theorems for circuit simplification
  • Explore the use of simulation tools like LTspice for circuit analysis
  • Investigate the impact of dependent sources in circuit calculations
Electrical engineering students, circuit designers, and anyone involved in analyzing or solving electrical circuits.
Color_of_Cyan
Determine ( I L ) in the following circuit (the current "above" the 3 kΩ resistor).
http://imageshack.us/a/img31/1530/circuits215.jpg
Voltage division law
V (for series resistor) = (V in) * [ (resistor)(total series resistance) ]
Kirchoff's rules: I in = I out
Total potential difference in a loop = 0
Okay, a lot of this is still new to me, so forgive me if I miss something.
(The "I L" should also be "I l," as it is just a listed current )
But, there's no potential difference given so how are you able to find the current asked? Would you say voltage is equal for everything in the circuit?
I try to sum all current out from left to right on the bottom as:
I tot = I l + 4(I x) - 3mA but still unknowns everywhere when all I want is I l.
Where should I start?
Try to apply millman's theorem
Not sure how to apply that theorem but I found something else that might be closer and does help. From what I think I understand you simplify everything in the circuit as much as possible and to just like 2 parallel wires except for the same node / wire for the unknown stuff / current / elements you're trying to solve?Then you can use current / voltage division laws.
I get R eq = 1500 ohms and basically need the formula
I L = I eq [ R eq / (R eq + resistance on wire with unknown current you're trying to solve for) ]
The problem I think now is, what is (I eq)? I can simplify the independent (circles) currents to just 3 mA going up but what do I do with the dependent (diamond) current?
Or all still wrong?
Write a KCL node equation for the circuit.
Suppose the top node is at some potential V1. You should then be able to write terms for all the "unknown" currents in terms V1 and resistances. Solve for V1.
Which is the current going "out" ?
But ok I'm going to guess that it is the current going through the left 6k resistor):
(Current for 6 ohm resistor) = v / 6000 ohms
I think this is the current going out and then:
3(I X) = 3v / 2000 ohms
I X = v / 2000 ohms
I L = V / 3000 ohms
so
( 3v / 2000 ) + (v / 2000) + (v / 3000) - (v / 6000) - 0.003A = 0
v [ (4 / 2000) + (1/3000) + (1/6000) ] = 0.003A
v [ (1 / 400) ohms ] = 0.003A
v = 1.2 V for the top / bottom wire / node then?
V = IR, I = V / R
So that must mean I l = 1.2V / 3000 ohms
I l = 1.6 x 10^-4 A
I X = v / 2000 ohms
I L = V / 3000 ohms
so
Yes, that looks good. Excellent.
V = IR, I = V / R
I l = 1.6 x 10^-4 A
Whoops. The method is correct but there seems to have been a slip-up in the math.
  • · Replies 42 ·
