Engineering Find v_o and i_o in the circuit
  • Thread starter Thread starter physics=world
    Circuit
The discussion centers on solving for the output current (i_o) and voltage (v_o) in a circuit using Kirchhoff's Current Law (KCL). The user initially calculated i_o as 7.2 A, but the book states the correct answer is 6 A. The conversation highlights the need to consider the current through the 8 Ω resistor and emphasizes that all components are in parallel. A revised equation is suggested to clarify the relationships between the currents. The focus remains on correctly applying KCL to arrive at the accurate values for i_o and v_o.
physics=world
________________a
The 6 A is 9 A for the problem I'm solving for.
Only using KCL
I tried using KCL @ node a:
9 = io + i0/4
I get io = 7.2 A.
The answer in the book is 6A. What am I doing wrong?
What about the current through the 8 Ω resistor?
You should get something like:
##6A - i_o - \frac{i_o}{4} - i_x = 0##
Then using the fact everything is in parallel, you should be able to find what you need.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
