Find Wavelength of Light Through Slits
  • Thread starter Thread starter daisyi
    Light
To find the wavelength of light in a double slit experiment, the formula used is y = λL/d, where y is the distance of the first maxima from the center, L is the distance to the screen, and d is the slit separation. The user initially calculated the wavelength incorrectly by misidentifying the variables. The correct values are y = 0.03 m (half the distance between maxima), L = 2 m, and d = 9.12 x 10^-3 cm. After clarification, the user confirmed understanding of the formula and variables. This highlights the importance of correctly identifying parameters in physics calculations.
daisyi
Almost done guys :)
If the first order bright lines formed by two slits at a distance of 2 meters are 3 cm apart, find the wavelength of the light if the slit separation is 9.12x10^-3 cm.
So, to find the wavelength, this is what I did.
wavelength = 9.12 * 10^-5m * (2m/(3*10^-2m)) = .00608m.
i'm not understanding what i am doing wrong. any input would be helpful. Thanks!
You need to understand the formula for the double slit diffraction pattern. The distance of the first maxima (from the central maxima) is given by:
y = \frac{\lambda L}{d}
right, so y=9.12*10^-5m, d = 2m and L = 3*10^-2m.
Nope:
d is the distance between the slits
y is the distance of the first maxima to the center (this is half of the distance between those maxima).
thanks, i got it :)
