Dizzy
Basic projectile motion if you throw from ground level, to obtain a max distance in the x you'd want to throw at a 45° angle right? So as your initial height increases, your throwing angle will decrease and my guess is as your initial velocity increases your angle increases but not greater than 90°?? Anyways I want to find this expression of max distance in terms of theta.
y=yo+vosinθ⋅t-4.9t2
x=vocosθ⋅t
t=(-b+/-√(b2-4ac))/2a
So my attempt at finding this solution is finding t when height is 0 in terms of theta. In this problem I am assume vo and yo are constants that I can change when ever I like (seen later in desmos) So I used the quadratic formula to solve for t in terms of theta and those constants. I got t=((-vosinθ +/- √(vo2sin2θ+19.6yo))/-9.8) from now on I will refer to t as the - side of the +/- so t is that whole quadratic formula but not the plus, the minus end because I want the most negative on the top since there is a negative on the bottom to give me a larger positive time. I plugged that into my x=vocosθ⋅t. Then I took the derivative of that with respect to theta. In my mind if I find a zero on this derivative function I should be given a critical value which will represent maximum and minimum distances in the x direction. I am going to link my graph in desmos that will show what my derivative came out to be. So this graph is set to be rate of distance in the y-axis and theta as my x-axis. I am getting an angle of π in order to get a max distance when yo =50m and vo=4m/s. I want to throw backwards when I am at these initial conditions? This is definitely wrong. Can you help me find my error? Thank you.
EDIT: here is the graph. Sorry I didn't see the edit button you can ignore my reply https://www.desmos.com/calculator/usgxxh13qe
