Finding electric field of a wire within a cylinder
The problem involves finding the electric field generated by a wire with linear charge density surrounded by a cylindrical conducting shell. The focus is on determining the electric field as a function of distance from the wire, particularly in a configuration where the wire is within the cylindrical shell.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of Gauss's Law to derive the electric field for both the wire and the cylindrical shell. There is a focus on the need to clarify variable definitions to avoid confusion. Questions arise regarding how to handle the charge enclosed within the Gaussian surface depending on the distance from the wire.
The discussion is ongoing, with participants exploring different aspects of applying Gauss's Law. There is acknowledgment of the need to consider different cases based on the relative positions of the wire and the cylindrical shell. Guidance has been provided on how to approach the problem, but no consensus has been reached on the final expression for the electric field.
Participants note the importance of distinguishing between the variables representing the radius of the cylindrical shell and the distance from the wire. There is an emphasis on the implications of the charge enclosed within the Gaussian surface based on the chosen distance.
ConnorL0404
[/B]
A wire with linear charge density lambda is surrounded by a cylindrical conducting shell with radius r and surface charge density sigma. Find an expression for the electric field (magnitude and direction) as a function of distance d from the wire, on an axis perpendicular to the wire.
Gauss's Law
[/B]
I know the electric field of a wire is lambda/(2*pi*r*permittivity of free space) however, I don't know how to find the electric field of a cylinder with a wire within it rather than just a single point charge.
ConnorL0404 said:
[/B]
Gauss's Law
[/B]
First things first, you are going to have to rename one of your variables. The [itex]r[/itex] in the [itex]\vec E = \frac{\lambda}{2 \pi r \varepsilon_0} \hat {a_r}[/itex] is not the same [itex]r[/itex] as the radius of the cylindrical shell. You'll have to rename one of them to avoid confusion. [The problem statement tells you to change one of them to [itex]d[/itex].]
Second, can you use Gauss' Law to derive the [itex]\vec E = \frac{\lambda}{2 \pi r \varepsilon_0} \hat {a_r}[/itex] formula with only the wire (ignoring the cylindrical shell for the moment)? If you know how to do that, adding in the cylindrical shell is pretty straightforward.
Let's look at Gauss's Law:
[tex]\oint \vec E \cdot \vec {dA} = \frac{Q_{enc}}{\varepsilon_0}[/tex]
The [itex]dA[/itex] is a differential area element on your chosen Gaussian surface. Choose your Gaussian surface wisely to take advantage of symmetry. If you choose it wisely in certain special cases like this one, the closed integral is easy to solve. The idea is that you want the dot product of the electric field and the differential area element to be constant over the entire surface [Edit: possibly ignoring things like cylindrical endcaps, if you can show that [itex]\vec E \cdot \vec{dA} = 0[/itex] at the endcaps]. That way the left hand side simply becomes [itex]EA[/itex], where [itex]A[/itex] represents a formula for the Gaussian surface's area. (You can't do this for everything, but you can do this for a) things with spherical symmetry, b) infinitely long wires/cylinders [like this problem] or c) infinite planes.)
The right hand side only depends on the charge enclosed within the Gaussian surface. Anything outside the Gaussian surface doesn't matter.
Then solve for [itex]E[/itex]. You can add the unit direction vector in as a final step. :wink:
So after I find the equation for the Electric field of the cylindrical shell, do I just simply add it to the other equation i.e. E-Field of wire+ E-field of Cylinder?
You'll have to break it up into two parts: one part where [itex]r[/itex] is less than [itex]d[/itex] and the other part where [itex]r[/itex] is greater than [itex]d[/itex].
Remember the right hand side of Gauss' Law, particularly [itex]Q_{enc}[/itex]. The only thing that goes into the equation is the charge enclosed within the Gaussian surface. Anything outside doesn't count. When [itex]r[/itex] is less than [itex]d[/itex] is the charge on the cylindrical shell within the Gaussian surface? What about when [itex]r[/itex] is greater than [itex]d[/itex]?
[Edit: Since [itex]d[/itex] is the independent variable, perhaps I should have switched those around and rather asked, "When [itex]d[/itex] is less than [itex]r[/itex] is the charge on the cylindrical shell within the Gaussian surface? What about when [itex]d[/itex] is greater than [itex]r[/itex]?"]
  • · Replies 16 ·
