Finding entropy change when house leaks heat
To find the change in entropy when heat leaks from a house, the total entropy change must account for both the loss inside and the gain outside. The heat loss from the house is calculated as ΔS = -Q/TH, while the heat gain outside is ΔS = Q/TL. The correct approach involves summing these two entropy changes to find the overall change. The final calculation yielded an entropy change of approximately 0.563 J/K, which was accepted as correct. Understanding both sides of the heat transfer is crucial for accurate entropy calculations.
rubenhero
b) The temperature inside a house is Tin = 19.2° C when the temperature outside is Tout = 10.7° C. If Q = 5.49 kJ of heat leak from the house to the outside, find the change in entropy caused by this process.
W = QH - QC, dS = dQ/T
dS = 5.49kJ/283.7K = .0193514276kJ/K
The answer I calculated was wrong, should I include the entropy inside the house?
Any help is appreciated!
Hi rubenhero! :smile:
Inside you lose ΔS=-Q/TH.
Outside you gain ΔS=Q/TL.
The question in your problem statement is not entirely clear, but I suspect the total change in entropy is intended, which is the sum of both entropy changes.
Thanks you for responding. You were right, I just did the sum of the entropy loss and gain and got an answer of .5629265733 J/K. Webassign marked my answer as right. Thanks again for your help!
You're welcome! :)
