Finding equation of equlibrium for rod and two blocks
The discussion focuses on deriving the equilibrium equation for a slender rod attached to two blocks, factoring in the weight, spring constant, and angle. The key equations involve balancing forces and moments, leading to a relationship between the weight (W), spring constant (k), rod length (l), and angle (θ). A discrepancy arises between the user's derived equation and the book's answer, prompting questions about the calculations and assumptions made regarding tension and distances. Participants clarify the approach to solving for the angle θ and the interpretation of forces in the system. The conversation emphasizes the importance of accurately applying equilibrium conditions to derive the correct relationships.
KEØM
A slender rod AB of weight W is attached to blocks A and B which move freely in the guides shown. The constant of the spring is k, and the spring is unstretched when \theta = 0. (a) Neglecting the weight of the blocks, derive an equation in W, k, l, and \theta which must be satisfied when the rod is in equilibrium. (b) Determine the value of \theta when W = 4.5 lb, l = 30 in., and k = 1.8 lb/ft.
Here is a picture of the problem. It is number 4.60
"[URL title="download file from Jumala Files"]http://jumalafiles.info/showfile2-15016951829111680748225395249314210/problem460.pdf [/URL]
\Sigma F_{x} = 0
\Sigma F_{y} = 0
\Sigma M_{B} = 0
F_{s} = ks = lsin(\theta)
\Sigma M_{B} = lsin(\theta)(klsin(\theta) - lcos(\theta)A_{y} + W(l/2cos)(\theta) = 0 where A_{y} is the reaction force at A.
\Sigma F_{y} = A_{y} - W = 0
\Sigma M_{B} = lsin(\theta)(klsin(\theta) - lcos(\theta)W + W(l/2cos)(\theta) = 0
\Sigma M_{B} = l^2sin^2(\theta)k - (l/2)cos(\theta)W = 0
\frac{2lk}{W} = \frac{cos(\theta)}{sin^2(\theta)}
After inverting both sides and using the identity sin^2(\theta) + cos^2(\theta) = 1
I get for an answer:
sec(\theta) - cos(\theta) = \frac{W}{2lk}
The book's answer is tan(\theta) - sin(\theta) = \frac{W}{2lk}
Can someone tell me where I went wrong?
Thanks in advance,
KEØM
I approached it a little more simply using the Tension in the arm L.
At equilibrium you have in the vertical direction
mg = T*sinθ
In the horizontal direction
kx = T*cosθ
Noting that x = (1 - cosθ)*(L/2)
then solving. I think that yields the answer in the book.
Thanks for the reply LowlyPion. I have a couple of questions. When I solve your equations I get:
tan(\theta) - sin(\theta) = \frac{2W}{kl}.
I have probably done something wrong though.
I don't understand how you got your x. Your equation is telling me that it is half the distance of the rod minus the horizontal distance that half of the length of the rod covers. I don't understand how that gives you x.
One more question: Shouldn't your forces in the x direction be kx = -Tcos(\theta).
Or shouldn't one of your equations have a negative?
Thanks again,
KEØM
Isn't W acting at L/2 along the rod? It just seems to me that you would want to take the tension from that point to A.
As to the minus sign, the Tension is oppositely directed at A and L/2, I just took the direction that they seemed to be naturally acting.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
