Find Force Vector for Given Position & Torque
To find the force vector F that results in the given torque from the position vector r, the cross product r x F must equal the torque vector. The determinant method is used to express the cross product, leading to a system of equations based on the components of the vectors. The initial equations derived from the determinant are clarified, emphasizing that the correct interpretation is crucial for solving for F. The discussion highlights the importance of accurately expanding the determinant to avoid confusion in the calculations. The participant expresses gratitude for the clarification and indicates a better understanding of the problem.
DOMINGO79
I am having a huge problem trying to answer the following question:
Given the position vector r = 3i + 4j + 5k and torque = 16i - 20j - 5k, find the force vector F which will give the correct result, so that torque = r x F
Can anyone please help me solve this!:confused:
Write out the cross product as a determinant with the force vector's components a,b,c. Then you can solve:
\det{\begin{bmatrix}\mathbf{i}&\mathbf{j}&\mathbf{k} \\ 3&4&5 \\ a&b&c\end{bmatrix}}=16\mathbf{i}-20\mathbf{j}-5\mathbf{k}
16i-20j-5k = i j k = i(4c-5b)-j(3c-5a)+k(3b-4a)
3 4 5
a b c
16i = i(4c-5b) -3(16 = 4c-5b) -48 = -12c + 15b
-20j = -j(3c-5a) → 4(20 = 3c-5a) → 80 = 12c – 20a
-5k = k(3b-4a) 32 = 15b -20a
32 = 15b-20a 32 = 15b-20a
5(-5 = 3b-4a) → -25 = -15b+20a, so what am I doing wrom?
why are the unknowns totally canceling out?
They don't cancel out. You're not expanding the determinant correctly.
For example, your first equation should read: 16 = 4c - 5b and nothing else.
Wow...
Hey, thanks alot, I think I just opened my eyes:bugeye: and understand how to complete the question...
If I have anymore Q's, I will let you know, thanks...
