Finding Harmonics: Frequency Multiplication?
  • Thread starter Thread starter lilkrazyrae
    Harmonics
To find harmonics, multiply the harmonic number by the fundamental frequency. For a fundamental frequency of 343Hz, the first four harmonics are 343Hz, 686Hz, 1029Hz, and 1372Hz. This calculation is straightforward for a string vibrating in a fundamental mode. While complexities can arise in different scenarios, this case is simple and typical. The discussion confirms that there is nothing special about this situation regarding harmonic calculations.
lilkrazyrae
In finding harmonics do you just multiply the harmonic number times the frequency? Find the first four harmonics when f=343Hz would be f1=343Hz, f2=686Hz, f3=1029Hz, and f4=1372Hz. This just seems too easy.
That's basically it! There are situations where it's a bit more complex (oddly shaped waveguides, nonuniform media etc.) but that's not the case here (unless there is other pertinent information you have not disclosed).
The problem reads exactly A string vibrates in a fundamental mode at 343Hz. Find the first four harmonics. Is this a special situation??
Nope - nothing special about that! For a string the harmonics are simple!
