Convergence of Improper Integrals: Exploring the Power of p
In summary: It is e^{-p+1} instead.In summary, the integral ∫ e-x/xp dx converges for all x and p if ∫ 1/xp dx converges.
c.dube
27
I'm trying to refresh my knowledge of Calc II, and I'm going through improper integrals right now. The problem I am trying to solve is:
For which numbers [itex]p\geq0[/itex] does [itex]\int_0^\infty \frac{e^{-x}}{x^{p}}[/itex] converge? Justify your answer.
So far, I've split up the integral into two halves (0 to 1 and 1 to infinity) but I'm stuck because I don't know the next step to take. Any help? Just a hint would be great.
Good start breaking it into pieces. Let's look at the [itex]x \geq 1[/itex] piece first.
Does
[tex]\int_{1}^{\infty}e^{-x}dx[/tex]
converge?
Then, can you show that
[tex]\frac{1}{x^p} \leq 1[/tex]
for all [itex]x \geq 1[/itex] and [itex]p \geq 0[/itex]?
For x ≥ 1:
0 < e-x < 1/xp
Therefore, the integral ∫ e-x/xp dx converges in the interval [1,∞] if ∫ 1/xp dx converges.
Now look at the interval [0,1]. Again we have:
0 < e-x < 1/xp
(This is because e-x=1 at x=0 and e-x=1/e at x=1, but 1/xp=+∞ at x=0 and 1/xp=1 at x=1.)
Therefore, again the integral ∫ e-x/xp dx converges if ∫ 1/xp dx converges.
Look at the p-test to decide the value of p.
OK, so [itex]\int_1^\infty e^{-x}[/itex] converges because the limit as x goes to infinity is finite. Now, because [itex]\frac{1}{x^{p}}[/itex] is decreasing and the largest case would be one, it is always less than or equal to one (is there a more rigorous way of saying this?).
Anyways, moving on to case between 0 and 1, we can prove the top converges by seeing that the limit as x goes to infinity is finite. Can I use the same logic as the first half, and, if so, what is a more rigorous way of saying it? And finally, does this mean the answer is any p greater than or equal to 0? Thanks in advance.
EDIT: Wait, so if the bottom must converge, does that mean, by the p-test, that p must be greater than 1? I'm a little confused.
Never mind.
If [itex]x \geq 1[/itex], then [itex]x^p \geq 1[/itex] for any [itex]p \geq 0[/itex]. This is equivalent to
Now multiply both sides by [itex]e^{-x}[/itex] (which is positive for all x) to get
[tex]\frac{e^{-x}}{x^p} \leq e^{-x}[/tex]
Thus since the right hand side is integrable from 1 to [itex]\infty[/itex], the same is true of the left hand side.
OK that makes sense to me, but where does it leave me? How do I bridge the gap to finding what, if any, p works? Thanks
c.dube said:
OK that makes sense to me, but where does it leave me? How do I bridge the gap to finding what, if an, p works? Thanks
My previous post shows that the integral from 1 to [itex]\infty[/itex] converges for all [itex]p \geq 0[/itex]. So the result depends entirely on the behavior from 0 to 1.
From 0 to 1, then, don't we have the exact opposite logic, e.g. [itex]\frac{1}{x^p}[/itex] will always be greater than or equal to one? And therefore it diverges for all p, leaving me with an answer p = null set? Haha thanks for bearing with me I don't know why my brain isn't getting this one.
Have you tried p=0?
Yes, that's correct. In fact, if [itex]p > 0[/itex], then [itex]\frac{1}{x^p} \rightarrow \infty[/itex] as [itex]x[/itex] decreases toward 0. However, that doesn't automatically mean you can't integrate it!
No. For some values of p, the integral will be finite even though the function shoots off to infinity near the origin. Loosely speaking, it depends on how "thick" the tall part of the function is, and that is controlled by p.
Try computing the indefinite integral of [itex]1/x^p[/itex], and see what values of p will cause the result to blow up at x = 0, and which ones won't.
Oh ok so if p=0 then the [itex]x^p[/itex] just becomes one, leaving only [itex]e^{-x}[/itex], which converges, so the answer would be p=0?
So the indefinite integral is:
[itex]\frac{x^{-p+1}}{-p+1} + c[/itex]
When x=0, doesn't the integral become 0 for every p except p=1, where you get the indeterminate form [itex]0^0[/itex]? Gah I really don't know why I'm not getting this.
No, consider separately these two cases:
[tex]-p + 1 > 0[/tex]
[tex]-p + 1 < 0[/tex]
And also observe (important point) that your formula for the integral is wrong if [itex]-p + 1 = 0[/itex].
Ohhhhh ok so we have:
[itex]1-p<0[/itex]
Now, that will go to infinity. The other case:
[itex]1-p>0[/itex]
Will always be zero. So, the function doesn't blow up when p<1. Would that indicate that the answer is [itex]0\leq p<1[/itex]? And what about the case where p=1? Thanks again for your patience it is very much appreciated.
For p=1, we have:
∫ e-xx-1 dx
= e-xlog(x) + ∫ log(x)e-x dx
= e-xelog(log(x)) + ∫ log(x)e-x dx
= e-x+log(log(x)) + ∫ log(x)e-x dx
I'm pretty sure this diverges, since log(0) isn't defined. If this diverges, then every p for p>1 also diverges.
[itex]1-p<0[/itex]
[itex]1-p>0[/itex]
Yes, that's right. That shows that you can integrate [itex]1/x^p[/itex] if [itex]0 \leq p < 1[/itex], but it blows up if [itex]p > 1[/itex].
So what can you say about integrating [itex]e^{-x}/x^p[/itex] in these two cases? (Hint: [itex]e^{-x}[/itex] is bounded between 1 and [itex]e^{-1} \approx 0.368[/itex] in the interval [0,1]. It never goes anywhere near 0, nor does it shoot off to infinity.)
Finally, p = 1 is a special case. In this case, [itex]1/x^p = 1/x[/itex]. What's the indefinite integral of [itex]1/x[/itex]?
So, on [itex]0\leq p<1[/itex], is [itex]\frac{e^{-x}}{x^p}[/itex] integrable and therefore converges?
As for p=1, we have the indefinite integral of lnx. But that's undefined at x=0, so am I missing your hint?
Correct.
OK, but look at the behavior as x approaches zero. [itex]\ln x[/itex] approaches [itex]-\infty[/itex]. So the integral of [itex]1/x[/itex] diverges. What does this imply about the integral of [itex]e^{-x}/x[/itex]?
That it diverges, yes? And so the final answer would be [itex]0\leq p<1[/itex]?
Ah sweet! Thanks so much for your help it was much appreciated.
You're welcome, good luck.
1. What is "finding integral convergence"?
"Finding integral convergence" is a mathematical concept that involves determining whether an integral, which is a mathematical representation of an area under a curve, converges or diverges. This is important in many areas of science and engineering, as it helps to determine the behavior of certain functions or systems.
2. How is integral convergence determined?
Integral convergence is determined by evaluating the integral using various methods, such as the comparison test, limit comparison test, and the integral test. These tests help to determine whether the integral converges or diverges based on the behavior of the integrand, or function inside the integral, as the limits of integration approach infinity.
3. Why is it important to determine integral convergence?
Determining integral convergence is important because it helps to understand the behavior of a function or system. It can also be used to solve problems in physics, engineering, and other fields that involve calculating areas or volumes. Additionally, it allows for the evaluation of infinite series, which are commonly used in scientific and mathematical calculations.
4. What are some applications of integral convergence?
Integral convergence has many applications in science and engineering. For example, it is used in physics to calculate the work done by a variable force, in chemistry to determine the rate of chemical reactions, and in economics to calculate the present value of money. It is also used in signal processing, control theory, and other fields that involve analyzing functions and systems.
5. Are there any limitations to determining integral convergence?
Yes, there are some limitations to determining integral convergence. In some cases, the integral may be too complex to evaluate using traditional methods, or it may not have a closed-form solution. In these cases, numerical methods, such as the trapezoidal or Simpson's rule, can be used to approximate the value of the integral. Additionally, the tests used to determine convergence may not always provide a definitive answer, and further analysis may be needed to fully understand the behavior of the integral.
