Finding internal resistance from 2 circuits
The discussion centers on determining the internal resistance of a battery connected to different external resistances, with power losses of 50W and 200W noted for 10 ohms and 4 ohms, respectively. Participants emphasize that while the internal resistance remains constant, the voltage drop across it changes with varying current, adhering to Ohm's Law. A quadratic equation approach is suggested to solve for the internal resistance based on the power dissipation equations. There is confusion regarding the application of different power loss formulas, highlighting that the total emf does not solely appear across the internal resistance. The conversation concludes with a collaborative effort to clarify concepts and solve the problem effectively.
BathroomUser
A battery with an emf of 60 V and an internal resistance (r) is connected to a 10 ohm external resistance. The power lost inside the battery is 50w. The same battery is then connected to a 4.0 ohm resistance. The power loss is 200w. What is the internal resistance of the battery?
Diagrams:
http://i.imgur.com/LUF75yR.png
P=VI
P=I2R
V=IR
P=V2/R
P=VI1 4P=VI2
VI1=VI2/4
4 x I1=I2
4(V/(r+10))=(V/(r+4.0)
4/(r+10)=1/(r+4.0)
4(r+4.0)=r+10
4r+16.0=r+10
r=-2 Ω
Re:
P=vi1 4p=vi2
and
4 x I1=I2
If the current is x4 different would the voltage drop across the internal resistance be the same?
The voltage drop across the internal would be the same as we're using the same source and the only difference is the external resistor
So, for the same resistance (the internal resistance), if the current changes the voltage drop remains the same? What happened to Ohm's Law?
Likes 1 person
But the thing is that we have r+10 and r+4 equating to our resistance, so couldn't it be the r be the same number though?
Yes, the internal resistance r stays the same. No, the potential drop across r is not constant if the current changes. Ohm's law is, well... it's the law! :smile:
Try writing an expression for the power developed by r for a given load (say the 10 Ohm load). Knowing that the result should be 50W, solve for r. (you should find a quadratic equation that returns two potential solutions). Do the same for the other load. What do you find?
Likes 1 person
Thank you so much! I enjoy that you are not exactly spoon feeding me the answer but instead going through the logistics of the concepts! I will apply those and come back if a problem arises
A new problem has arisen when I use the r value I find to plug into other power loss formulas, ie P=VI and P=V^2/R the answer are different.
Attempts:
P=VI I=V/R
P=60(60/(10+2))
P=V^2/r
=60^2/2
Attempts:
P=VI I=V/R
P=60(60/(10+2))
P=V^2/r
=60^2/2
The voltage across r is not the same as the voltage across r + 4Ω, or r + 10Ω. That is, the whole emf of 60V does not appear across r.
Rather than inserting additional steps to find the portion of the 60V that appears across r in each case, employ another expression for the power dissipated by a resistor R with current I flowing through it: P = I2R
Likes 1 person
Makes sense. I guess I wasn't thinking clearly. Thank you so much for the help though!
