How Do You Calculate the Moment of Inertia for a Uniform Solid Block?
To calculate the moment of inertia for a uniform solid block with mass 0.172 kg and dimensions 3.5 cm x 8.4 cm x 1.4 cm, the formula involves integrating r^2 dm, where r^2 is the distance from the axis of rotation. The correct substitution for dm is based on the block's density, expressed as density times dxdydz for a three-dimensional integral. For simplification, if integrating over just two dimensions, dm can be represented as height times dxdyd. Understanding these substitutions is crucial for accurately calculating the rotational inertia about the specified axis. Proper application of these principles will yield the desired moment of inertia.
demonelite123
a uniform solid block has mass 0.172 kg and edge lengths a=3.5cm, b=8.4cm, and c=1.4cm (c is the height of the rectangular solid).Calculate its rotational inertia about an axis through one corner and perpendicular to the large faces.
i know the formula is integral of r^2 dm, but i have no idea what to do here. i have r^2 = a^2 + b^2. but i don't know how what to substitute for dm.
Hi demonelite123! :smile:
(try using the X2 tag just above the Reply box :wink:)
If r2 = x2 + y2, then dm = density times dxdydz (or, if you're only integrating over x and y, then dm = hdxdy). :smile:
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
