Finding net electric field at different locations
The discussion focuses on calculating the net electric field at specific points due to two charges on the x-axis: q1 (+16.5 µC) at x1 = +3.0 cm and q2 (-19 µC) at x2 = +9.0 cm. The initial approach of setting the electric fields equal (E1 = E2) was incorrect; instead, the electric fields from both charges should be calculated separately and then summed as vectors. The correct formula involves using Coulomb's constant and the distances from each charge to the point of interest. Participants clarified the importance of using proper units and distances in calculations, leading to a more accurate understanding of the electric field contributions. Overall, the conversation emphasizes the need for careful consideration of vector addition in electric field calculations.
nckaytee
Two charges are placed on the x axis. One charge (q1 = +16.5 µC) is at x1 = +3.0 cm and the other (q2 = -19 µC) is at x2 = +9.0 cm. Find the net electric field (magnitude and direction) at the following locations.
(a) x = 0 cm
magnitude= ? N/C
direction= ?
(b) x = +6.0 cm
magnitude= ? N/C
direction= ?
I set E1=E2
[K(+16.5*10^-6)]/X^2 = [K(-19*10^-6)]/(X+.06)^2
After canceling everything out I get 16.5(X+.06)^2 = 19X^2
Then solving for X I get .8219 and -.0289
I am not sure what I am doing wrong. The (10^-6) should cancel out right?
(a) x = 0 cm
magnitude= ? N/C
direction= ?
(b) x = +6.0 cm
magnitude= ? N/C
direction= ?
I set E1=E2
First of all, welcome to PF.
But as to setting E1=E2 ... Why?
The E field at any point is
\sum \vec{E}
Perhaps a better approach is determining the E field contribution from each charge and adding them together remembering of course that you are adding E field vectors?
So, It would be "[K(+16.5*10^-6)]/X^2 + [K(-19*10^-6)]/(X+.06)^2" instead?
I was following another example I found and now I am very confused.
Perhaps it would be less confusing if you dropped X from your equations. And then calculated each separately and added?
What is crucial is the distance from the charge. That and Coulomb's constant and the charge determine the E field contribution from that point.
So in the first one the E-field for the first charge at x= .03 m (dimensions in meters for the constant to be valid) resolves as:
\vec{E_1} = \frac{k*q_1}{r^2} = \frac{k*16*10^{-6}}{.009}
Then calculate the contribution for the negative charge that is at .09m.
Those two together determine the field at x=0.
\vec{E} = \vec{E_1} + \vec{E_2}
When I do that I get -5111111.111
E= [(9x10^9)(16x10^-6)]/(.009) + [(9x10^9)(-19x10^-6)]/(.0081)
What am I doing wrong?
3 cm2 is .0009 not .009 as I originally typed. My mistake.
that makes it 16*107 - 2.1*107 = 13.9*107
So, for part B I would just change the radius value?
Pretty much that looks like it.
Units are N/C - Newtons/Coulomb
Thank you so much. I have a hard time understanding Physics and this really helped.
Great. Good Luck then.
