Finding normal force from kinetic and potential energies
The problem involves a skier moving through a dip in a circular path, requiring the calculation of the normal force at a specific point based on kinetic and potential energy principles. The subject area includes concepts from mechanics, specifically energy conservation and forces in circular motion.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of energy conservation to find the skier's speed at the lowest point of the dip. There are questions about the consistency of the variables used, particularly the definitions of heights and speeds at different points.
Some participants have provided guidance on checking the signs in the calculations and clarifying the definitions of the variables involved. There is an acknowledgment of a potential sign error in the calculations, and the discussion is ongoing with attempts to clarify the setup and assumptions.
There is a lack of access to the diagram referenced, which may affect the clarity of the problem setup. Participants are also navigating the implications of height definitions in relation to the skier's position.
lsu777
A 69.2-kg skier encounters a dip in the snow's surface that has a circular cross section with radius of curvature of r = 13.2 m. If the skier's speed at point A in the figure below is 8.13 m/s, what is the normal force exerted by the snow on the skier at point B?
http://educog.com/res/prenhall/walker/Physics_3E/Chap08/graphics/walk0850.gif"
As shown, h = 1.63 m. Ignore frictional forces.
ok so we are given:
mass=69.2kg
radius=13.2m
Velocity1=8.13 m/s
Change in Y=1.63m
gravity=9.81m/s^2
we know KE1 + PE1=KE2 + PE2
with potential energy2= O
ok so first thing I did was try and find velocity2 with the formula
so 1/2*m*v1^2 + 0= 1/2*m*V2^2 + m*g*Y
so V2=sqrt(V1^2 - 2*G*Y)
I got V2=5.84092
Then I did sum of Forces Y=(normal force - m*g)= mass * Arad
Arad= V2^2/R
so normal force=(mass*(V2^2/R))+m*g
so normal force = 709.473 N
can somebody smarter then me please check this. I think I got it wrong the first time because of math error. ****ing lon-capa sucks and doesn't give you any info. I have one more shot to get it right.
I can't see the diagram without a username and password. Is B lower than A, or higher? Is v1 the speed at A, or B? Make sure everything is consistent.
A is original heigth, B is the bottom of the circle, below A.
V1= Velocity at A
picture was attached.
I got V2=5.84092
Is v1 the speed at A, or B? Is Y the y coordinate at A, or B? Your method is correct, but you have a sign issue. (One way to see that you made a mistake is to note that V2 is smaller than the initial speed, which doesn't make sense.)
v1 is speed at A, Y is the height at B to the level of A. can you tell me where I made a mistake on my signs?
If your height at A is 0, your height at B should be negative, not positive.
  • · Replies 20 ·
