Finding permability of free space from Magnetic Field vs. Current graph
The discussion centers on a graph plotting Magnetic Field (T) against Current (A), where the calculated slope is 0.0012, deviating by 10^-3. The user converted Magnetic Field data from Gauss to Tesla and provided specific current values in Amperes. Participants are asked to suggest reasons for the slope discrepancy and inquire about the data used for plotting the graph. The conversation emphasizes the importance of accurate data conversion and potential sources of error in the experimental setup. Understanding these factors is crucial for determining the permeability of free space accurately.
BrownPrincezz
I graphed Magnetic Field (T) vs Current (A) and my slope was equal to 0.0012 which is off by 10^-3. Can someone suggest why this could be happening?
What data did you use to plot the graph?
I used the Magnetic field data in Gauss (I did convert it) and Current in Amperes
http://i41.tinypic.com/auic6o.jpg this is what it looks like
Current (A)
0.1
0.175
0.25
0.325
0.4
0.475
0.55
0.625
0.7
0.775
0.85
0.925
Magnetic field (G)
1.7
2.6
3.5
4.3
5.3
6.1
8.8
9.6
10.6
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
