Finding pressure at narrow end of segment
  • Thread starter Thread starter sona1177
    Pressure
The discussion centers on calculating the pressure at the narrow end of a tapered pipe segment, given the pressure and speed at the larger end. The user initially attempts to use the equation P = ρg(d) but struggles with the definition of "d" and its relevance in this context. Clarification reveals that "d" was mistakenly interpreted as the length of the narrow segment instead of its diameter. Participants emphasize the need to apply Bernoulli's equation correctly, focusing on the fluid's density, velocity, and pressure without considering potential energy since the pipe is horizontal. The conversation highlights the importance of understanding the relationship between cross-sectional area and fluid velocity in pressure calculations.
sona1177
A horizontal segment of pipe tapers from a cross-sectional area of 50.0 cm^2. The pressure at the larger end of the pipe is 1.20 x 10^5 Pa and the speed is .040 m/s. What is the pressure at the narrow end of the segment?
I know how to do the problem using Bernoulli's equation but why can't I manage to get the correct answer using P=rho(g)(d). where rho=1000, g=9.8, and d=.00798 m
Could you explain what d is in your equation.
As the pipe is horizontal there is no potential energy consideration.
I also note that there is no information given about the change in the cross section area.
Maybe you could clarify the question?
d is the length of the narrow segment which I obtained by dividing area/pi and taking the sq root to get the radius. I then multiplied that by 2.
Ooops! Sorry about leaving that info out. It tapers from 50-> 5 cm^2
I don't quite understand what you are doing here.
The expression ρhg in the Bernoulli formula includes the terms
ρ the density of the fluid
g acceleration due to gravity
h the height of the liquid above the reference level
You have written ρdg but stated that d is "the length of the narrow segment". However, your calculation looks like it is for the diameter of the narrow segment.
Neither of these values, length or diameter, are the ones in the expression.
As the tube is horizontal, you don't need this term anyway, you just need the terms
½ρv² and p to find the pressure.
The value of v is found from the volume flowing per second being equal in both parts of the tube.
