Finding Solutions for Intricate Homework Problems
The discussion revolves around a double integral involving polar coordinates, specifically the integral $$\int \int r\cos^2(\theta)dr - r^2\cos(\theta)\sin(\theta)d\theta$$. Participants are exploring how to compute this integral in the context of a line integral defined in spherical coordinates.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to rewrite the differential $$dr$$ in terms of $$d\theta$$ and question the substitutions made in the original problem. There is also a focus on how to reduce the double integral to a single integral.
Some participants have provided guidance on parametrizing the path and using the chain rule to relate $$dr$$ and $$d\theta$$. There is acknowledgment of the need for a linear function for $$r(\theta)$$ based on specific angle values.
One participant notes that the original problem statement was not fully provided, which may lead to confusion regarding the context of the integral. Additionally, the path for the line integral is broken into segments, which may affect the approach to solving the problem.
leonardthecow
Hi there! So I'm working on an old homework problem for review so that I actually have the solution, but I'm not sure how to compute a certain part. Here it is:
$$\int \int rcos^2(\theta)dr - r^2cos(\theta)\sin(\theta)d\theta$$
The solution involves (what I think is) a rewrite of $$dr$$ in terms of $$d\theta$$, but I don't follow the substitutions the author makes.
Any thoughts on how to approach a problem like this? Thanks!
You have titled this thread "line integral". But it doesn't look like a line integral since it is a double integral. You haven't given us a statement of the problem or any equations to work with. We aren't mind readers.
Well, the original problem is to compute the line integral of $$v= r\cos^2(\theta)\hat{r} -r\cos(\theta)\sin(\theta)\hat{\theta} +3r \hat{\phi}$$ around a path depicted in the text. The path, in terms of spherical coordinates, runs as follows, broken into 3 segments:
1) $$r:0 \rightarrow 1, \theta = \frac{\pi}{2}, \phi = 0$$
2) $$r=1, \theta= \frac{\pi}{2}, \phi: 0 \rightarrow \frac{\pi}{2}$$
3) $$r: 1 \rightarrow \sqrt{5}, \phi = \frac{\pi}{2}, \theta: \frac{\pi}{2} \rightarrow \arctan(1/2)$$
The integral comes from computing the dot product of v with dl along the third path. I didn't inclue the rest of the problem since my question is one of how to reduce th double integral to a single integral in theta, as the author did in the solution.
Assuming that (3) is a straight line, you can parametrize it using the angle ##\theta## as the curve parameter. You can then use the relation ##dr = \frac{dr}{d\theta} d\theta## (essentially the chain rule) to rewrite the differential. Note that what you want for ##r(\theta)## is a linear function such that ##r(\pi/2) = 1## and ##r(\arctan(1/2)) = \sqrt 5##.
Ah thank you! That's the step I was missing, 3 is a straight line. This is exactly what I needed.
