Finding Specific Heat of 2 substances mixed
In summary, .02 kg of substance is heated in a bath of boiling water until its temperature is apporoximately 100*C. The substance is the placed in an insulated container that is holding .10 kg of water at 25*C. The final equilibrium temperature of the mixture is 32*C. The specific heat of substance, in kilojoules kilogram . degree Celsius, is 2.16.
cdhotfire
193
In an experiment, .02 kg of substance is heated in a bath of boiling water until its temperature is apporoximately 100*C. The substance is the placed in an insulated container that is holding .10 kg of water at 25*C. The final equilibrium temperature of the mixture is 32*C. The specific heat of substance, in kilojoules kilogram . degree Celsius, is.
I tried making the change of heat of the substance equal to change of heat of wate, but that didnt give me the right awnser, I know this because it is a multiple choice awnser. I would really appreciate help on this. Thxs before hand.
Oops, that title is so wrong, suppose to be, Finding Specific Heat of Substance. What was I thinking. :mad:
That should work... what are the answers available?
A. 2.16
B. 2.095
C. 2.57
D. 4.19
E. 1.0
cdhotfire said:
A. 2.16
B. 2.095
C. 2.57
D. 4.19
E. 1.0
I got 2.16...
I did:
(.02 kg)(68*C)c=(.1 kg)(1)(7*C)
and got c= .5147
How did your get 2.16?
cdhotfire said:
I did:
and got c= .5147
you got the answer in calories/(K*kg) multiply it by the specific heat of water in KJ
I don't understand.
I did...
cdhotfire said:
I don't understand.
That "1" in the formula for heat absorbed by water.It's 1 calory.It should be in [itex] KJ Kg^{-1}K^{-1} [/itex]
Daniel.
For the specific heat of water, use 4.19kJ/(K*kg) instead of 1 calorie/(K*kg)
So its
(.02 kg)(68*C)c=(.1)(7*C)(1 ?)
what is the specific heat measured in, isn't cal/g*C?
cdhotfire said:
I obiously don't care what letter it is, I want to know how to do it.
If you actually read between the line... you would notice that we've actually told you how to do it...
Dextercioby, should we consider helping someone this rude?
Okay,u did it fine,but put wrong units.If u put instead of calories [itex] KJ Kg^{-1}K^{-1} [/itex],your answer will coincide with the one at point "a".
Daniel.
apchem, I posted that before, because, dex said i got A, and told me to post my work. I said I did post it, and I didnt really care what the letter awnser was.
Anyways thxs for the help, didnt mean to be rude.
Use the 4.19 in the place of 1... since that is the correct unit not 1 calorie/(K*kg)
cdhotfire said:
So its
Yes,it's just that u need to express it in KJ/Kg*C (or Kelvin,they are the same thing,just scaling is different).
Daniel.
I c how, 1 cal/g*C= 4.184 J/kg*C, correct?
Oops, 4.184 is already in KJ, I just noticed, that 1 cal/g*C=4184 J/kg*C. Thats what's started this whole question.
Well thxs for all the help, and again I didn't mean to be rude. :smile:
but even still, it ask for the awnser in kilojoules. Wouldnt I multiply it by 1000?
nahh... 1 calorie = 4.184 J... so multiply the answer by 4.184 and see what you get...
Yes u would have to multiply it.Else your answer would be in J/Kg*C instead of KJ/Kg*C
Daniel.
Srry for the confusion, I changed my post. :smile:
Daniel.
first of all Its 4.184J/g*K(orC)
and if you convert it to 4.184kJ/kg*K(orC)
you don't need to multiply by anything. so thus... only need to muliply by 4.184
I see your change... well then you will have to divide by 1000 and multiply by 4184 to your original answer of 0.516
1. How do you find the specific heat of two substances mixed together?
To find the specific heat of two substances mixed together, you will need to measure the initial temperature of both substances and the final temperature after they have been mixed. Then, use the formula Q = mCΔT, where Q is the heat transferred, m is the mass of the mixed substances, C is the specific heat, and ΔT is the change in temperature. Rearrange the formula to solve for C and you will have the specific heat of the mixed substances.
2. Can you use the specific heat of each substance separately to find the specific heat of the mixture?
No, you cannot use the specific heat of each substance separately to find the specific heat of the mixture. When two substances are mixed together, their specific heats will change due to how they interact with each other. This is why it is necessary to measure the specific heat of the mixture separately.
3. Why is it important to find the specific heat of two substances mixed together?
Finding the specific heat of two substances mixed together is important because it allows us to understand how much energy is required to change the temperature of the mixed substances. This information is useful in various applications such as cooking, industrial processes, and understanding the behavior of different materials.
4. Is the specific heat of a mixture the same as the average of the specific heats of the individual substances?
No, the specific heat of a mixture is not the same as the average of the specific heats of the individual substances. As mentioned before, when two substances are mixed together, their specific heats will change due to how they interact with each other. Therefore, the specific heat of a mixture cannot be calculated by simply taking the average of the individual substances' specific heats.
5. How does the specific heat of a substance affect its ability to hold or release heat?
The specific heat of a substance determines how much heat energy is required to change its temperature. A substance with a higher specific heat will require more heat energy to increase its temperature, and therefore it has a greater ability to store heat. On the other hand, a substance with a lower specific heat will require less heat energy to increase its temperature, and therefore it has a lower ability to store heat.
