How Do You Calculate Tension in Unequally Lengthed Cables Lifting a Beam?
  • Thread starter Thread starter tooperoo
    Cables
To calculate the tension in the chains lifting a 5m beam, the Law of Cosines is suggested to determine the angles formed by the chains. A free body diagram of point B is essential, considering that the horizontal tension components are equal and opposite, while the vertical components relate to the upper chain's tension. The discussion highlights the importance of understanding the beam's center of mass, which should ideally be directly below point B for stability. The original poster expresses confusion about the right triangle formed by the chains, but it is clarified that the 3-4-5 triangle configuration applies. The thread emphasizes the necessity of showing prior attempts at solving the problem to receive assistance.
tooperoo
A 5m long uniform beam AC with mass of 600kg is being lifted from the ring at B by two chains (AB, 3m long and CB, 4m long). Determine the tension in chain AB and CB when the beam is clear of the ground.
I tried dividing it into 2 right angle triangles but doesn't the non-equal length sides mean it's not a right angle triangle? I'm struggling to find the angles because of this.
If there's tension in the two chains, then you are going to have a 3-4-5 triangle. This is a right triangle.
Do you think that the beam is going to remain horizontal after both ends are off the ground? If not, which end do you think will be higher? How many unknowns do you assess are required to solve this problem?
Chet
Use the Law of cosines to find the angles. Then do a free body diagram of point B (keeping in mind that the horizontal components of the tension in each wire are equal but opposite, and that the sum of the vertical components equal the tension in the upper wire above B) and solve for the vertical components using vectors and the angles.
The 3 side will be higher, no? But how do we find the missing side of the right angle triangle? c^2 = a^2 + b^2 would give the missing height, but a different answer depending on if the 3m side is used or the 4m side is used.
To solve this, all i would need is the angles of the right angle triangles right? I can solve the tensions from there?
As I already said, if there is tension in the chains, then the triangle is going to be a right triangle, with sides 3, 4, and 5. Let θ be the angle that the beam makes with the horizontal after it loses contact with the ground, and let T1 and T2 be the tensions in the two wires. Note that θ also represents the angle through which the entire 3-4-5 triangle rotates. Thus, specifying θ completely specifies where all points on the triangle will move to.
Chet
This is what I think about how much the load swings...
Surely the center of mass of the beam should end up directly below B? It would seem to represent the lowest energy state (gravitational PE).
Good point. My mistake. It seems so obvious: I don't know what I was thinking!
Been there, done that! :smile:
Likes 1 person
Then what's next?
Kerima Sales said:
Then what's next?
The last post when the thread was active was from August 2013. The OP (Original Poster) was last active in January 2014. Somehow I doubt that he or she will interested in continuing the problem here.
If you are working on the same problem and need help you'll need to show your own attempt at solution just as though you were posting the problem yourself. No help can be given until effort is shown (it's in the forum rules!).
Likes Chestermiller
