Finding the basis for a vector space
The problem involves finding a basis for a vector space defined by the set of 2x2 matrices A such that CA=0, where C is a specific 2x2 matrix. The original poster attempts to derive the conditions imposed by the matrix multiplication.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster describes multiplying the matrix C by a general 2x2 matrix and deriving equations from that multiplication. They express confusion about the redundancy in the equations and the next steps needed to find a linearly independent set that spans the vector space.
Some participants provide guidance by suggesting that the original poster should express the matrix A in terms of fewer variables based on the derived equations. There is an indication of progress as the original poster acknowledges understanding after receiving help.
Participants note the presence of redundant equations in the system derived from the matrix multiplication, which affects the determination of the basis for the vector space.
aanandpatel
Find a basis for the following vector space:
The set of 2x2 matrices A such that CA=0 where C is the matrix : 1 2
3 6
I multiplied C by a general 2x2 matrix : a b and got 4 equations but two of these equations are the
c dsame and it seems as I am going around in circles. I know I need to find a set that is linearly independent and spans the original set but I'm not sure how to proceed.
Help would be greatly appreciated :)
Cheers
That sounds exactly like what you want. Clearly not any 2 x 2 matrix will do, and indeed the two equations you have will fix two relations between a, b, c and d. But since there is not a single unique solution, you should also have at least one parameter which you can vary.
Talking with a practical example is probably clearer, so can you show us which equations you got?
Have a matrix by the way (quote my post to see the code): ##\begin{pmatrix} a & b \\ c & d \end{pmatrix}##
sorry had no idea how to matrices on the forum
C = ##\begin{pmatrix} 1 & 2 \\ 3 & 6 \end{pmatrix}##
A(my general matrix) = ##\begin{pmatrix} a & b \\ c & d \end{pmatrix}##
CA=0 so when I multiplied, I got
a+2c=0
b+2d=0
3a+6c=0
3b+6d=0
But two of those equations are the same and I don't know what to do after that.
Right, so if you get all the information you can from those equations, you can write your matrix A in terms of two variables only - for example, just a and b.
What does A look like then?
Makes sense now - got it!
Thanks a lot - help was much appreciated :)
  • · Replies 18 ·
  • · Replies 17 ·
  • · Replies 0 ·
