Finding the center of mass of a piecewise function
To find the center of mass (COM) of a piecewise function, the shape can be divided into simpler components like parallelograms and triangles. While calculating the COM for each shape is possible, integrating the equations directly may provide a more accurate result. The discussion emphasizes that even if the shapes are not perfect parallelograms, they can still be treated as point masses for COM calculations. There is some confusion regarding how integration relates to finding the COM versus just calculating area. Clarification is needed on the necessary multipliers for the integration process to accurately determine the COM.
JorkThePork
Find the center of mass of the "lightning bolt" shaped piecewise function as shown below (or in the desmos project: https://www.desmos.com/calculator/g6crwsecp1)
Xcm = A^-1 * ∫ a b x * (f(x) - g(x)) d x
Ycm = A^-1 * ∫ a b .5((f(x)^2 - g(x)^2) d x
I understand that I can divide this shape into a few parallelograms and a triangle and calculate the center of mass of each, but am confused as to what I should do after that. My physics teacher also wants us to use integrals, but I'm assuming I can calculate the COM of each parallelogram and triangle by simply integrating.
You can find the CM of the two parallelograms and the half-parallelogram which will give you 3 point masses at the locations of these CMs. Then you can find the CM of the 3 point masses the usual way.
the two seemingly big parallelograms actually are not parallelograms because of how I designed the lightning bolt (the equations I used are here https://www.desmos.com/calculator/g6crwsecp1). However, I could break the shape up into 2 big parallelograms, 2 very thin parallelograms, and a triangle. I'm assuming I could still then find the CM of the 5 point masses the usual way.
Yes, you can carve it up into simple non overlapping shapes, but since you have equations why not just integrate them and add the (signed) results?
Sorry, I’m a little confused how this would give me the center of mass. wouldn’t this just give the area?
So what do you need to multiply the expressions by before integrating?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
