Finding the chemical equation
  • Thread starter altenrim
  • Tags
    Chemical
In summary, the conversation discusses a problem involving finding the chemical equation and name of an incorrectly labeled element, given the molecular weight of a formula and the weights of two of the elements. The overall molecular weight of the formula is 150 grams/mole and there is 1.00 gram of chlorine and 1.36 grams of a falsely named element, Illinium. The question relates to finding the formula and determining the true identity of Illinium, and also calculating the portion of the molecular weight that is due to chlorine.
altenrim
My question is about finding the chemical equation and name of wrongly labeled element given the molecular weight of the formula and weights of two of the elements. The problem gives the overall molecual weight of the formula as 150 grams/mole. Then it says there is 1.00grams of chloriene in it and 1.36 grams of a "so called" Illinium. From this, how do I go about finding the formula for the problem and what element Illinium really is?
If there are 1.00grams of chlorine for every 1.36 grams of "Illinium" how many grams of the 150grams/mole of the molecular weight is due to chlorine?
To find the chemical equation and name of the wrongly labeled element, we first need to use the given information to determine the molecular formula of the compound. Since the overall molecular weight is 150 grams/mole, we can set up an equation using the weights of the two known elements, chlorine and "so called" Illinium:
150 grams/mole = 1.00 grams of chlorine + 1.36 grams of "so called" Illinium + x grams of unknown element
Solving for x, we get a value of 147.64 grams for the unknown element. This means that the molecular formula of the compound is Cl1.00Illinium1.36X147.64, or simply ClIlliniumX.
Next, we need to determine the true identity of "so called" Illinium. To do this, we can look at the periodic table and see that the closest element in terms of atomic weight is iodine (I). Therefore, we can conclude that "so called" Illinium is actually iodine.
Now, we can write the complete chemical equation for the compound as ClI1.36X147.64. This means that the compound contains 1.00 gram of chlorine, 1.36 grams of iodine, and 147.64 grams of the unknown element, X.
In summary, to find the chemical equation and name of the wrongly labeled element, we used the given information to determine the molecular formula of the compound and then identified the true identity of the wrongly labeled element. This process is important in ensuring the accuracy and reliability of scientific experiments and data.
1. What is a chemical equation?
A chemical equation is a symbolic representation of a chemical reaction, where the reactants and products are written as chemical formulas and the coefficients indicate the relative amounts of each substance. It shows the conservation of matter and energy in a chemical reaction.
2. How do you balance a chemical equation?
To balance a chemical equation, you must ensure that the number of atoms of each element is the same on both sides of the equation. This can be done by adjusting the coefficients in front of each compound. The Law of Conservation of Mass states that matter cannot be created or destroyed, so balancing a chemical equation is necessary to maintain this law.
3. What is the purpose of finding a chemical equation?
The purpose of finding a chemical equation is to understand the chemical reaction that is taking place. By knowing the reactants and products involved, as well as their relative amounts, we can predict the outcome of the reaction and understand the underlying chemistry and principles involved.
4. What is the importance of knowing the chemical equation?
Knowing the chemical equation allows us to make informed decisions in various fields such as industry, medicine, and agriculture. It helps us understand the properties and behavior of different substances, and allows us to manipulate and control chemical reactions for specific purposes.
5. How do you write a chemical equation?
To write a chemical equation, you must first identify the reactants and products involved in the reaction. Then, write their chemical formulas and use coefficients to balance the equation. It is important to follow the rules of chemical nomenclature and use correct symbols and formulas for each substance. Additionally, state symbols (s, l, g, or aq) can be used to indicate the physical state of each substance.
