Finding the forcing frequency to maximize the amplitude
Jamin2112
Consider the following underdamped oscillator governed by:
u''(t) + ¥u'(t) + w02u(t)=Fcos(wt)
(a) Find the ge...
(b) The hom...
(c) What is the forcing frequency w for which the amplitude R in the previous part attains a maximum? Show that it is always less than the natural frequency w0.
So, I solved the problem in part (a) and put it in the form Rcos(wt-µ) in part (b). I've looked over my work several times; the answer is messy. You can try it for yourself if you really feel like it. Otherwise, trust me when I say that the long term solution (getting rid of the homogenous equation since it involves crap in the form e-at, where a is positive) is
[F(w02-w2)]/[(w02-w2)2+(wy)2]*√[1+(wy)2/(w02-w2)2]*cos(wt-tan-1(wy/(w02-w2)).
...so how do I find the right w to maximize the amplitude? I have no idea. Please explain in detail. This assignment is due tomorrow morning.
if you have a function in terms of w for the amplitude, could you differentiate and set to zero to find the maxima?
There has to be a better way
Likes laurynmn
note there should be no homogenous part in the steady state forced solution anyway, only the driven frequency term
actually maybe you can clean that up a bit and its ok? - notice when you find the amplitude transfer function (divide by Fcoswt), the cos part with the tan inside will disappear as its just the same frequency response shifted by a phase given by the tan term
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
