Finding the magnitude of the electrostatic force from a thin rod
To find the electrostatic force on an electron near a uniformly charged thin rod, the problem requires integrating the contributions from each infinitesimal segment of the rod, as Coulomb's law applies only to point charges. The total charge Q can be divided by the length L of the rod to determine charge density, and the distance from the electron to each segment must be adjusted accordingly. The standard formula for the force between point charges, F = k*q1*q2/r^2, is insufficient for this scenario due to the continuous nature of the charge distribution. Calculus, specifically integration, is necessary to accurately compute the total force acting on the electron. Understanding these concepts is crucial for solving the problem effectively.
nuagerose
The figure shows a uniformly charged thin rod of length L that has total charge Q. Find an expression for the magnitude of the electrostatic force acting on an electron positioned on the axis of the rod at a distance d from the midpoint of the rod.
http://ezto.mhecloud.mcgraw-hill.com/13252699451980596522.tp4?REQUEST=SHOWmedia&media=c21q56a.png
F = \frac{kQ}{d^{2}}
I know how to find the force from a point charge using the equation above, but I am not sure how to set up this problem because it is a charged thin rod. I was thinking I could divide Q by L as the charge in the above question and d-\frac{L}{2} as the d in the above equation.
Can you tell what is the formula for the force between two point charges q1 and q2 at a distance d from each other ? The formula you have written doesn't make much sense.
F = (k*q_{1}*q_{2})/r^{2}
Hope this is right. I suppose q1 would be the charge of the thin rod and q2 would be the charge of the point, which is e.
Hope this is right.
Right
No.Coulomb's law applies only to point charges.You cannot apply this directly when a continuous object like a rod is present.We will have to consider rod as composed of infinitely many point charges.
Are you familiar with calculus ?You will need integration whenever a continuous charged body is present.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
