Finding the terminal velocity of a model rocket from a list of velocities
The discussion revolves around analyzing rocket data from a 20,000-foot launch to calculate terminal velocity and the drag coefficient. The user has time, altitude, and velocity data but struggles to graph the velocities effectively to identify terminal velocity. Suggestions include using Excel to calculate velocity as a function of height and focusing on the data from burnout to apogee, as drag coefficients differ during ascent and descent. There is a consensus that while calculating terminal velocity during coasting is challenging, it may be possible to estimate an upper bound for free fall terminal velocity. The user aims to validate the drag coefficient, which is typically around 0.75 but varies with different rocket designs.
  • #51
Ok, so this is your senior project. Thats good to know. I wasn't planning on doing the work for you, once you start you will see why.
So the path forward that I have in mind begins by writing a differential eq. that describes the motion after burnout up to apogee. I already have done that for you...I'm not going to try to hide that. That is your free bee. Do you understand where it comes from? You descibe how it is formulated back to me?
  • #52
lol, my senior project is building a rocket that hits 10 to 20,000 feet, which we have done, and to build a ADS system for said rocket. This is just analysis so i have some numbers to work with that will help with design. Im not graded on the question i asked about terminal velocity.
This data however, will be used in the report so i guess it will be graded haha.
Ill try my best to describe what you have and if i understand it. I have been researching terminal velocity as a exponential and its the first time i have seen it this way. I might have seen it in calc class but it was probably not given as a terminal velocity problem.
http://www.dzre.com/alex/hp221_f03/notes/vterm/vterm.html
  • #53
Oh, you know what. It just dawned on me the way I was thinking would have taken you into wonderland, and we probably would have never got out!
  • #54
should i start crying now?
  • #55
The new way will tell us with substantially less wandering in a mathematical forest!
Still, can you describe the differential equation to me. What assumptions do you think it has?
  • #56
Sorry, what's ADS? Do you mean DAS?
Also, maybe this is unreasonable, but can you outfit and program a rocket to not deploy the parachute until a little before the ground, and gather data on velocity/altitude on the way down? That way the rocket won't be damaged, and you will have the terminal velocity data that you want.
EDIT/ADD -- BTW, I didn't see a parachute mentioned explicitly in the thread so far (I could have missed it), but the statements about falling tail down and not wanting to destroy the rocket made me assume a parachute. Otherwise, the rocket should fall nose down (fins/tail up, just like my arrows), and running the Data Acq System another minute or so should not drain the batteries...
  • #57
But the shoots are deployed out of the nose cone? If there is any susbstantial velocity I'm picturing it deploying, wrapping around the rocket, and smashing into the ground.
  • #58
Parashoots? LOL
So it won't deploy at 100mph nose down? Maybe boost the ejection charge for the chute?
  • #59
Parashoots? LOL
:woot:
It sounds pretty risky... but I have no idea.
  • #60
Me neither, but it seems like a useful line to think about. For example, it may be that a small side drag feature needs to temporarily added to the nosecone to be sure it clears the rocket on the way down when it's popped. This will slow the rocket a bit during ascent, but who cares, since the data we want is at the end of the descent.
It's up to the OP/"Rocketman" to let us know if this might work. :smile:
  • #61
Parashoots? LOL
Anyhow, I honestly thing we can figure it out from the data they have. But maybe they could just do an uncontrolled decent into earth on graduation day to verify calulations o0)?
  • #62
the chute/shoot doesnt deploy for 24.6 seconds and apogee hits at 27.1 seconds. So the chute pops right before apogee. The chute is below the nose cone.
This image was a test launch to 1 mile
15 foot shock cord, 5 foot chute
i can get permission to allow a rocket to go ballistic but it has to be a smaller rocket haha.
as for the equation... Im not even sure where to start of what it would look like.
F=m(dv/dt)
F=drag -gravity
m(dv/dt)=Fd-mg
then not sure where to go from there haha
  • #63
:-p
F=m(dv/dt)
F=drag -gravity
m(dv/dt)=Fd-mg
You're on the right track. On the way up which way is the drag force acting?
  • #64
erobz said:
:-p
on the way up drag should be pushing down, same with g, and mg.
some equations have Fr=bv, what is b?
if mass cancels out, then i can separate and then integrate. but from here, not sure
dv/(g-bv)=dt
then i get a crazy equation with e in it. if i take the limit as time gets large, vt is left
  • #65
Correct, so what is the sign in front of the ##F_d##?
Thats linear drag. Your rocket is only going to be in that regime for a short period of time.
For rockets (and most thing that fall through the air ) we typically use quadratic drag. They are both there, but quadratic drag dominates for higher speeds:
##F_d = \beta v^2##
dv/(g-bv)=dt
Don't jump too far ahead. We won't actually have to solve the ODE to get what you are after (unless you want to afterward).
  • #66
##F_d = \beta v^2##
Don't jump to far ahead. We won't actually have to solve the ODE to get what you are after (unless you want to afterward).
i have never seen the Fd=bv^2 equation... or i was not paying attention. I checked my fluids book and i do not see it....
ok, so lets go back. Fd should be negitive. so
m(dv/dt) = -Fd - mg
  • #67
m(dv/dt) = -Fd - mg
It's in your fluid book somewhere. You should have a chapter about lift and drag. In mine its Chapter 11!
  • #68
ill try and find it. For now, i have the diff eq as shown above. Whats the next step?
thanks for all the help. Seeing this in a new way really solidifies the knowledge and understanding of what is really going on
  • #69
So you plug in the quadratic drag force to equation and divide through by ##m## and you will arrive at what I have written in post #40.
After that take a moment to study it and identify all the data that you have, or could calculate from the data you captured.
  • #70
ok, now i see how you get the equation from post 40, and where did quadratic drag force come from?
your book must be way better than my book. I just went through my section on drag which was 9.3, the rest of chp 9 was on flow. I think they picked this book because it focused more on stocks theorem and fluid flow. We spent one lecture on drag.
  • #71
I’m not sure I’m following what you are asking.
Different books can have different focuses sometimes. You’ll just have to Google “quadratic drag” in your spare time” and take my word for it for now.
  • #72
the bv^2 term that i plug into the diff eq, thats what i meant haha. where does that bv^2 come from. once i get equation from post 40, im not to sure what values to place in for b. but i will worry about it in the morning and i will integrat first to see what i get. I have a 3 hour train ride home from school and they just had to tow my train so i am delayed an hour.... its almost midnight too and we have 4 feet of snow
  • #73
It comes from the equation you should be already familiar with, namely, Fd = 1/2*rho*v2*Cd*A.
At first approximation, 1/2, rho, Cd, and A are all constant, so it simplifies down to Fd = some constant * v2.
Now, for this, you probably have to account for varying air density, so it would be good if you could look up an atmosphere model (or better still, if you know the temperature that day, a temperature corrected atmosphere model), and then you'll want to basically try to fit your deceleration data to a model using this formula, with 1/2 (obviously), rho (from your atmosphere model), A (from whatever your chosen reference area is), and v2 all known (you know v from your data, which incidentally you should use accelerometer based speed rather than baro based speed if possible, it's much more accurate), and thus you can solve for Cd.
You know Fd because you know the burnout mass of your rocket and you had an accelerometer onboard, though you're going to (at least in my experience) have issues getting any kind of accurate data below a few hundred mph because you start getting limited by accelerometer discretization at that point. Because of this, you can rearrange your equation to Cd = Fd/(1/2*rho*v2*A), and then just solve for your Cd vs V curve.
(Also, the Raven is a great little altimeter, so I'm glad to hear you're using it)
Likes LT72884 and erobz
  • #74
Yikes! That’s a good storm.
(As was pointed out by @cjl ) you have velocity data in sufficiently small time steps that you should be able to compute ##a_{avg}## and ##v_{avg}## for each time step. Then you will solve the eq in post #40 for ##\beta##, and make a plot using that eq and calculated values ##a_{avg}## and ##v_{avg}##. We are hoping to find that this plot for ##\beta## can be reasonably aproximated by a straight - nearly horizontal line, implying ##\beta## and hence ##C_d## are a constant. If it turns out that it isn’t straight-horizontal then we can talk about what to do.
  • #75
yeah, the storm was AMAZING!! we had a thundersnow. Its very rare to happen, but extreme winds and extreme lightning during a snowstorm. it was my first one i have ever seen so i freaked out a little because i thought "tornado"
Once i am awake and ready, i will begin the process of solving all this.
Solving for beta, do you want that done before or after the integration?
thanks
  • #76
thanks
You must find the functional form of ##\beta## before you do the integration to get ##v(t)##, as it may change the integrand dramatically depending on whether or not its constant or some function of ##v##.
  • #77
That would be Stoke's Theorem.
  • #78
Yeah, i just spelled in wrong. One of my paitents i work with is name Stockely but its pronounced Stokely like stokes
  • #79
erobz said:
I don't know exactly the numbers, but I would expect something negative greater than ##g## given the equation:
$$ \frac{dv}{dt} = - \left( g + \frac{\beta}{m}v^2 \right)$$
solving for B i get:
is that how i needed to solve for it?
I know mass of the rocket, acceleration of the rocket, gravity, launch time and temp, rho, and velocity
where dv/dt is, do you just want me to use the acceleration values there?
  • #80
I want you to take the average acceleration across each time step (just for the truncated data).
##a_{avg} = \frac{ v_2 - v_1 }{ t_2- t_1}##
and arithmetic average velocity over the same time step
## v_{avg} = \frac{v_1 + v_2}{2}##
You are then going to plot ##\beta## vs ##v_{avg}##
Likes Chestermiller and LT72884
  • #81
ok, so the v^2 term in beta, am i using the ACTUAL sensor velocities or the average velocity?
and for the average velocity what is v1 and v2 because i only have the sensor velocity as posted in the excel.
thanks
  • #82
thanks
The average values.
  • #83
erobz said:
The average values.
ok, great. and i think i know what you mean now. from time 0.25 to 0.3, that would be v1 and v2, then from time 0.35 to 0.4 would be another v1 and v2? correct?
  • #84
LT72884 said:
ok, great. and i think i know what you mean now. from time 0.25 to 0.3, that would be v1 and v2, the 0.35 to 0.4 would be another v1 and v2? correct?
Yep,thats it...
  • #85
erobz said:
Yep,thats it...
ok, great. ill give that a go and see what happens. thanks for all the help. eventually i will see whats happening haha
  • #86
ok, there are 2 ways i could do this, which one is the best? i have this way
the 2 yellow velocities are averaged, the 2 blue and 2 green are as well. OR, i can do
(200.71+199.82)/2
(199.82+198.85)/2
(198.85+198.08)/2
(198.08+197.23)/2
  • #87
(200.71+199.82)/2
(199.82+198.85)/2
(198.85+198.08)/2
(198.08+197.23)/2
Just start at the cell D3 . Write all the formulas as:
in cell D3:
Formula: = (C3 + C2)/(2)
And just drag it down. Same with the acceleration (different formula).
  • #88
in cell D3:
thats how i did it at first, by dragging the formula down. But i noticed it used a previous value so wasnt sure that would mess up the data or not, but i will go ahead and do it the way i was going to haha
  • #89
move the formula down one cell. Then just stop it at the end. you are going to truncate the data a bit more to remove some outliers, or you could remove them point by point if you feel like it.
  • #90
sorry for late reply. have had some crazy issues with my train rides. My train to school had to get towed by another train haha, then yesterday a truck fell off the overpass onto the train.
Ok, so how do i know Fd based on burnout mass?
thanks much.
I also preferer to use an accelerometer over barometric pressure readings for velocity.
for the quadratic drag, i see what they did. Beta is just a constant of all the constants
  • #91
here is what i have for beta, using avg acel for dv/dt. B=(-ma-mg)/v^2
the numbers are odd, and when i plot it.... man it looks nasty
  • #92
This is the exact trick we used in atmospheric modeling to determine the final steady state ozone column without running the calculation out to infinite time.
Likes erobz and LT72884
  • #93
thats cool. Its been great the last couple of days with this personal challenge of mine. This entire question is not for an assignment, but for my understanding and growth. I am so used to bookwork and homework questions, that i decided to branch out and ask myself how i would do this. I will USE this data though in my senior capstone report.
Likes russ_watters
  • #94
##a_{avg}## is negative. The acceleration of the rocket is opposite its direction of motion. What you have is positive. What calculation did you do for that? After you fix it, please share the plot so we can try to interpret it. Or maybe you can offer you interpretation of it... more than the "numbers are odd, and it looks nasty", think about if its average behavior aligns with any expectations about ##\beta##.
  • #95
i used a=(v2-v1)/(t2-t1) but if it needs to be -, then i will switch it around
  • #96
If you did use that formula you would be getting a negative value, and you aren't.
  • #97
exactly. But excel shows that i am using the correct formula. Ill just reverse the C3 and C2 values, that will produce negative numbers. I just dont know if beta is correct.
if i let B=(rho)(Cd)(Ar)(0.5) and solve for cd, i get 0.72 for the first entry. Now, Cd does change ALOT during a flight due to many factors. So a plot of Beta should look almost like a switch back type trail..
  • #98
if i did indeed solve for the Cd correctly, i can use that in the terminal velocity equation by taking the average Cd over a specific time. When velocity is 0.3m/s my drag coef is -44,000 so its gotta be the right numbers.
or did you have a different aproach to find Tv?
  • #99
Well, you need to solve for the drag coefficient ##C_d## from ##\beta##. What do you calculate as ##\beta##, how did you get it? Please elaborate on what you are doing to get these numbers. Can you please share the plot? I think the variation you are seeing is noise, not the variation of ##\beta## as a function of ##v_{avg}##.
  • #100
B= (Cd)(Area)(rho)(0.5)
Beta is all the constants. From here i just plug in what i have and get the Cd. Bellow is the plot of beta.
