Finding Velocity of Falling Mass in Rotating Rod Problem
  • Thread starter Thread starter curt2121
    Rod
The discussion revolves around calculating the velocity of a 1kg mass at the top of a 1kg rod with a 2kg spherical base as it falls from a vertical position. Participants emphasize using conservation of mechanical energy and moments of inertia to solve the problem, noting that the length of the rod is crucial for accurate calculations. The center of mass is calculated, and the importance of the parallel axis theorem is highlighted for determining the moment of inertia about the system's center of mass. There is also a suggestion to model the system with different densities for the masses to simplify the calculations. Overall, the conversation focuses on the physics principles needed to approach the problem effectively.
curt2121
a 1kg rod of unknown length has a spherical base with a mass of 2kg and a mass of 1kg on the top. if it is allowed to fall over from vertical, what will the velocity of the 1kg mass at the top be when it falls down (no friction). a friend is driving me crazy with this since i gave him a little brain teaser before but physics isn't my thing so I'm not sure how to go about this. i can make a diagram later if that helps. thanks
I might be missing something here, but I don't think that the question is answerable as stated. I don't see how you can calculate the terminal speed of the top mass if you don't know how long the connecting rod is.
well the speed would be in terms of the length I'm assuming
Consider energy conservation.
um not really sure why this was moved since it isn't for a class but ok I guess. anyone knw of a solution?
This the forum for all textbook-type problems, whether for a class or on your own. :wink:
To solve the problem just use conservation of mechanical energy. Hint: If there is no friction, how will the center of mass move? What's the change in gravitational PE? (You may have to make some assumptions as to the size of the masses--treat them as point masses, for instance.)
for some reason i keep wanting to include the moment of inertia for the sphere (.4MR^2) since the base will have to roll over. Am I completely off on that? help is much appreciated since i'll have to take him to lunch wednesday if I don't figure it out
Not at all. Include the moments of inertia of all the parts.
ok I'm not quite sure how they're all supposed to fit together
lol the mass won't give u any velocities as the mass doesn't it the only things that affect velocity are acceleration, distance and time since u don't have distance nor time how r u goin to solve it
PS if u take him to lunch ask him 4 the answer and u'll find that there's a trick u didnt get it in u answer just like a cock has to get out an egg it's standing on a wall where the right of it there's fire and the left there's water where does it hav to put the egg??
If you have the sizes of the pieces (in terms of the length of the rod, perhaps) you can calculate the total moment of inertia of the system (which is just the sum of the parts). You'll need to relate the rotation of the system to the motion of the center of mass. (Which may not be so easy, since the base is spherical.)
If you were willing to model it as a stick with point masses on each end, the problem would be easier to solve. :wink:
from looking at the problem, i think it's safe to model the top mass as a point since it is fixed, but the bottom has to be spherical, that's the whole trick to it. I'm attaching a diagram for those visual learners. i know (at least i think if I remember right) the center of mass is:
cm of l=.5l (1kg)
cm of M(big mass at bottom) we'll say is at 0 and is 2kg
cm of m (little mass at top) is l and is 1kg
so the cm for the system is:
[(0*2)+(.5l*1)+(l*1)]/(4kg)= .375l
so that the cm of the system is 3/8 of the way up the length of the rod. am i good so far?
am i on track with that cm? and I'm not quite sure how to combine the moments of inertia of the different objects
Sure. Given your assumptions (spheres centered at y=0 and y=L; stick centered at L/2), your center of mass calculation is good.
To calculate the moment of inertia, you'll need to go a step further in assumptions. How big is the bottom sphere compared to the stick? For example: If the sphere has radius L/2, then the stick is only an L/2 long projection from the sphere. Treat the system as a set of three non-overlapping objects, find the rotational inertia of each object about the cm of the system and add them up.
(I hope you agreed upon a complete description of the problem before you accepted the challenge!)
so that the total moment of inertia is 2/5*2*R(radius of large mass)^2 +2/5*1*r(radius of small mass)^2, + 1/12*1*L^2=
4/5R^2+2/5r^2+1/12L^2?
then assuming the top and bottom masses have the same density, the volume of the top is half the volume of the bottom so that the radius of the larger object is 2^(1/3) times the radius of the larger object so that
R=r*2^(1.3) and the total equation becomes:
4/5r^(2/3)+2/5r^2+1/12L^2
does that seem right? did it get me closer?
Those are the moments of inertia of each piece about its own center of mass.
So you can't just add them. Use the parallel axis theorem to find the moment of inertia of each object about the cm of the entire system. Add those up and you'll have a meaningful moment of inertia for the system.
Also: If the stick is L long, do you mean for the complete object to have an overall length of: 2R + L + 2r ?
that last part abotu the length is correct. i don't remember ever hearing anythign about the parallel axis problem before. Well, it's possible i learned it as a different name. can you please enlighten me?
edit: just looked it up on wikipedia but I definitely don't understand the explanation there. it says
Iz=Icm+Md^2
I'm trying to solve for ICM so i want Iz-Md^2 but that just confuses me
now that I'm thinking, i hope i explained the problem right from the beginning. the rod isn't rotating about itself, ir's simply on a surface, say a desk and allowed to plop over to horizontal. does all this adding the moments of inertia still apply?
Yes it applies. The system will rotate as it falls, so some of the kinetic energy will be associated with the angular motion.
Iz=Icm+Md^2
Here's a useful discussion of the http://hyperphysics.phy-astr.gsu.edu/hbase/parax.html#pax". Briefly, if you know the moment of inertia of an object about an axis through its center of mass, the parallel axis theorem allows you to calculate its moment of inertia about any parallel axis. For example: You know that the moment of inertia of a stick about its center is 1/12 M L^2. You can use the parallel axis theorem to find its moment of inertia about the end:
1/12 M L^2 + M D^2 = 1/12 M L^2 + M (L/2)^2 = 1/3 M L^2
No, you have Icm and need Iz.
In your case you have the moments of inertia of each piece about its own center of mass. So you can use the theorem to compute the moments of inertia about the center of mass of the entire system.
It will be easier to get the final result if you assume the two end masses have different densities and the same radius. Assuming the lower ball stays in contact with the floor the whole time, when the top ball hits the floor the rod will be horizontal. Otherwise you have to figure out what the angle is in terms of R and L.
yes looking at it, that's what I'm going to do i think. this afternoon is crunch time for me to get down to it or i owe him lunch on friday. oh well, I'm still ahead in total since I usually get him with bio puzzles
