How Is Work Calculated When Friction Is Involved?
  • Thread starter Thread starter BarCode
    Friction Work
To calculate the work done by a 0.47N force pushing a 0.026kg pencil 0.26m against a friction force of 0.23N, the formula used is Work = Force x Distance. The calculated work is 0.1222J, derived from multiplying the force by the distance. Friction does not affect the work done by the applied force, as it only opposes motion rather than contributing to the work calculation. The main focus is on the applied force and the distance moved. Understanding the distinction between work done by the applied force and the opposing friction is crucial in this context.
BarCode
Calculate the work done by a 0.47N force pushing a 0.026kg pencil 0.26m against a force of friction of 0.23N.
Knowns:
F = 0.47N
m = 0.036kg
d = 0.26m
Ff = 0.23N
Since I know work = f*d, I do
w = 0.47N * 0.26m
= 0.1222J
I'm unsure of how to add friction into the calculation.
No. I am pretty sure you are correct. The force is 0.47N, and the distance is 0.26m. The friction is merely slowing the pencil down, which does not effect work.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
