Solve 1st Law of Thermo P20.38: Net Work & Energy
The discussion revolves around solving a thermodynamics problem involving an ideal gas undergoing a cyclic process. Participants explore how to calculate the net work done on the gas per cycle, emphasizing the use of the first law of thermodynamics and the ideal gas law. The net work is determined by analyzing the area enclosed in the PV diagram, accounting for both isothermal and isobaric processes. Calculations reveal that the net work done is negative, indicating work is done on the gas. The net energy added by heat is also derived, showing a relationship between work and heat transfer in the system.
maxpowers_00
An ideal gas initially at Pi, Vi, and Ti is taken through a cycle as in Figure P20.38 (n = 2.6).
Figure P20.38 (see attachment)
(a) Find the net work done on the gas per cycle.
PiVi
(b) What is the net energy added by heat to the system per cycle?
PiVi
(c) Obtain a numerical value for the net work done per cycle for 1.15 mol of gas initially at 0°C.
kJ
a) i though at first that W= area of the cycle, which came out to be 6.76 but, it was wrong.
as for part b, i have no idea
c) W=nRTln(vi/2.6vi) = W=(1.15)(8.314)(273)ln(1/2.6) = 2.5kJ but this also turned out to be wrong
any ideas?
thanks
Work done is given by
W=\int_{V_1}^{v_2} PdV
so clearly for process AB & CD W=0 as constant Volume Process
For BC : it would be WBC = nP0V0{n-1}
For DA : it would be WDA = -P0V0{n-1}
U can see net work done on the gas is the negative one so it is
W= -P0V0{n-1}
Net work done will be WBC + WDA
for the response!
To find the net work done on the gas per cycle, we can use the first law of thermodynamics, which states that the change in internal energy of a system is equal to the heat added to the system minus the work done by the system. In this case, since the gas is an ideal gas, we can use the ideal gas law, PV=nRT, to solve for the change in internal energy and then use that to find the net work done.
a) The net work done on the gas per cycle can be found by calculating the area enclosed by the cycle in the PV diagram. From the diagram, we can see that the cycle consists of two parts - an isothermal expansion and an isobaric compression. The area under the isothermal curve represents the work done by the gas, while the area under the isobaric curve represents the work done on the gas. So, we can calculate the net work done as follows:
W = Work done by the gas - Work done on the gas
= (Area under isothermal curve) - (Area under isobaric curve)
= (nRTln(Vi/Vf)) - (PΔV)
= (2.6)(8.314)(273)ln(1/2.6) - (Pi)(Vi-Vi/2.6)
= -2.5kJ (since PiVi=PfVf)
b) The net energy added by heat to the system per cycle can be found by using the first law of thermodynamics again. From part a, we know that W = Q - (nRTln(Vi/Vf)). So, we can rearrange this equation to solve for Q:
Q = W + (nRTln(Vi/Vf))
= -2.5kJ + (2.6)(8.314)(273)ln(1/2.6)
= 2.5kJ
c) To find the net work done per cycle for 1.15 mol of gas initially at 0°C, we can substitute the given values into the equation from part a:
W = (nRTln(Vi/Vf)) - (PΔV)
= (1.15)(8.314)(273)ln(1/2.6) - (Pi)(Vi-Vi/2.6)
= -1.2kJ (since PiVi=PfVf)
So, the
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
