First Law of Thermodynamics and Melting-Ice Scenario?
The discussion centers on the thermodynamics of an ice cube melting on a kitchen counter, with a focus on defining the system as closed. The first law of thermodynamics is applied, where the change in internal energy (∆U) is influenced by heat transfer (Q) and work done (W). Participants clarify that while heat moves from the environment to the ice cube, the work done by gravity is minimal compared to heat transfer. The ice cube and the resulting water are identified as a closed system, meaning no mass enters or leaves. Understanding the closed system concept is crucial for accurately applying thermodynamic principles.
Ortanul
In order to explain the change in energy of an ice cube removed from a refrigerator and placed on the kitchen counter, I consider it as a closed system (can exchange only energy but not matter).
For the first law of thermodynamics, ∆U = Q+W. I'm pretty sure that the sign of Q is positive due to the temperature difference that results in the energy transfer. What I'm not sure about is the work. In the process that ice melts, I figure there might be a increase in gravitational potential energy because its center of gravity descends, so should the sign of W be positive, too?
I'm also not sure about the nature of those three types of energy. I guess the nature of internal energy is the microscopic motion of the particles in the system, but what about the other two?
Any help would be appreciated!
Science news on Phys.org
As you are writing the question, to me, it seems not totally defined: what is the system?
For example, you are talking about an ice cube resting on a counter..., and the ice
melting. So, presumable you are considering the counter top, as part of the system, and likely
the air around the ice cube, etc... So, the question to me is ill defined..
Thermo dynamics deals with closed systems... Yours is not closed, so you need to try and understand what
a closed system is, as far as thermo goes..
Thanks for your reply!
And I'm still confused about the definition of closed system. May I consider the ice cube itself as a closed system while the counter and air as the surroundings?
As the ice cube melts, heat moves from the environment into the system and the internal energy of the water increases as it changes from ice to liquid. Work is done on water by the gravitational field of the Earth, but this is a small effect compared to the heat transfer.
Likes nasu
Thank you!
And do you think the ice cube itself can be counted as a closed system?
Ortanul said:
Thank you!
Yes. Yes. Yes! The ice cube plus then any water that forms from it is your closed system. This system is very well defined.
A closed system is one in which no mass enters of leaves.
Likes Ortanul
Been around 40 years since I took basic physics in college and while I remember doing some examples of insulation values / energy conduction, I doubt I could to the math now even if I could find the formulas. I have some some corrugated plastic sheet (think of the plastic signs you see on the side of the road) that is used in bee hives. Also have some used in a green house though a bit different in dimensions than this example but the general approach should still apply. Typically, both...
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
Thread 'Is Callen right in claiming dQ=TdS for all quasi-static processes?'
Hello! I am currently reading the second edition of Callen's Thermodynamics and an Introduction to Thermostatistics, and I have a question regarding Callen's definition of quasi-static. On page 96, Callen says: Another way of characterizing Callen's definition is that a process is quasi-static if it traces out a continuous curve in the system's configuration space. So far it's all well and good. A little later, Callen claims that the identification of $$TdS$$ as the heat transfer is only...
