First order ODE initial value problem
Shade
Given the below stated equations I need to find the exact polynomial given the initial condition.
y(0) = 1
y = 4*t*sqrt(y)
I simply disregard the initial value condition and get y = t^4
How can I find the fourth order polynomial with the given initial value?
( see also a former thread https://www.physicsforums.com/showthread.php?t=111094 )
Is it not possible to integrate a first order differential equation and also consider the initial value y(0) = 1 ?
Isn't there a typo? Where is y' ?
I assume the equation is written y'=4ty^(1/2) in which case it appears you have dy/dt=y' and this is a seperable equation. Solve for y and then solve for the initial value.
y(0) = 1
y = 4*t*sqrt(y)
I can see any "attempt at a solution". Saying "I simply disregard the initial value condition and get y = t^4" makes no sense! How did you "get y= t^4"? Don't you have to integrate somewhere and doesn't that introduce a "constant of integration?
The differential equation is \frac{dy}{dt}= 4t\sqrt{y}= 4ty^{\frac{1}{2}}
That can be written y^{-\frac{1}{2}}dy= 4t dt. Now integrate both sides.
It's interesting that there are two distinct solutions (actually, there are an infinite number of solutions). The "uniqueness" part of the "existance and uniquenss" theorem is not satisfied.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
