Flow of a Newtonian fluid down an inclined plane.
The discussion focuses on the velocity profile of laminar flow for a Newtonian fluid on an inclined plane, emphasizing the assumptions of incompressibility and fully developed flow. The participants analyze the forces acting on an infinitesimal control volume, particularly the balance of momentum flux and accumulation. A key point of contention is the constancy of pressure at a free liquid surface, with clarification that while pressure is atmospheric at the surface, it varies along the streamlines due to hydrostatic equilibrium. The discussion concludes that pressure remains constant along streamlines but is influenced by gravitational acceleration in the normal direction to the incline. Understanding these dynamics is crucial for accurately modeling fluid behavior in inclined planes.
siddharth
Homework Helper
I'm basically reading on how the velocity profile is found for a laminar flow of a Newtonian fluid down an inclined plane surface. (x is along the incline, y is perpendicular to the incline)
The assumptions being made are
- The fluid is Newtonian
- It's laminar
- It's fully developed
- It's incompressible
What the book did, was to take an infinitesimal control volume, find the forces acting on it, and equate it to the sum of the linear momentum flux and rate of accumulation of momentum in the c.v (along the x-direction)
I understand how the sum of the flux and the accumulation is zero. Next, the book evaluates the forces.
It says,
\sum F_x = P \Delta y|_x - P \Delta y|_{x+\Delta x} + \tau_{yx} \Delta x|_{y+\Delta y} - \tau_{yx} \Delta x|_y + \rho g \Delta x \Delta y \sin \theta
which I understand.
Then it says
Note that the pressure-force terms also cancel because of the presence of a free liquid surfaces.
This is what I don't understand. Why should the pressure be constant for a free liquid surface? For example, if we take a fluid between two cylinders, and rotate the inner cylinder (and make the same assumptions), then the centrifugal force (you know what I mean) would cause a pressure gradient along the radial direction. So, even at the free surface at the top, the pressure won't be constant.
Free liquid surfaces means it is at atm pressure, ie. zero pressure gauge.
Ouch. Yeah, it's kinda obvious now :blushing:
siddharth said:
w For example, if we take a fluid between two cylinders, and rotate the inner cylinder (and make the same assumptions), then the centrifugal force (you know what I mean) would cause a pressure gradient along the radial direction. So, even at the free surface at the top, the pressure won't be constant.
That's not true. If you leave the top open, as Cyrus said, the pressure is the atmospheric one at the top of the upmost film. The centrifugal force will curve the shape of the surface as it were a paraboloid, such that the hydrostatic pressure balances the centrifugal overpressure generated.
In your problem, the book should say that pressure is consant along the streamlines, but it is holding hydrostatic equilibrium normal to the plane, but instead with the gravitational acceleration g, with gcos\theta. So it is not uniform in the normal direction to the plane.
Yeah, I get it. Thanks
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
