Fluid flow through positive pressure gradient
Fluid flow can occur from a low-pressure region to a high-pressure region in specific scenarios, such as in a diffuser, due to the fluid's initial momentum. Although flow typically moves from high to low pressure, the kinetic energy of the fluid allows it to overcome the positive pressure gradient. As the fluid ascends the pressure gradient, its velocity decreases, converting kinetic energy into pressure energy, consistent with Bernoulli's principle. This energy balance explains the behavior of fluids in various flow measurement applications. Understanding this concept is crucial for studying fluid dynamics and engineering systems.
jacksimpson
I am a student of 11th standard and being introduced to Bernoulli's principle made me wonder , how does flow takes place in positive pressure gradient (i.e. from low pressure region to high pressure region), in a diffuser or a diverging part of a venturi meter , since we know that flow always takes place from high pressure region to low pressure region ?.
it will be very kind of you to clear my confusion.
Thank you.
The fluid having kinetic energy will decelerate as it climbs the pressure gradient.
Fluid motion does not always take place in the direction of negative pressure gradient; it always accelerates in that direction. If it already has motion against the pressure gradient, the gradient will serve to retard that motion, this the reason the velocity reduces through a diffuser.
yes sir i understand that. But can I say that the fluid at the diffuser inlet has enough momentum to overcome the positive pressure gradient and hence the flow. and as the flow occurs the kinetic energy is converted into pressure energy
Yes. That is essentially what Bernoulli's equation is telling you. It's an energy balance.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
